audio gurus, is this safe to run???
I have this sub and I'm thinking about going with this amp wired like so:
275w rms @4 ohms DVC
http://www.crutchfield.com/p_1081062..._1062&skipvs=T
500w rms @ 2ohms
http://www.sonicelectronix.com/item_...od-X500-1.html
wiring diagram
http://a248.e.akamai.net/pix.crutchf...4-ohm_mono.jpg
is this amp over kill? any recommendations would be great.
500w rms @ 2ohms
wiring diagram
It will do just fine. Lil bump in the trunk for the budget minded. Only recommendation is use a 4awg amp kit as a base. It's a good practice regardless and if you ever think you might upgrade some day in the future you won't have to pull out the old wiring.
milo
Audio / Security / Video
Jan 23, 2008 06:52 PM
