anyone with subs.. dynamat?
Old Sep 12, 2007 | 08:38 PM
zeBRAHz's Avatar
Default anyone with subs.. dynamat?
has a trunk kit ever significantly helped anyone with vibration/rattling/overall sound quality of subs? i feel like when my subs are loud, something in the backseat (i drive a civic coupe) is vibrating so hard.. like plastic against plastic. but everytime i sit back there, i can't find the source because i don't hear it happening. is there something small i can do to solve this problem, or should i buy the trunk kit.. i need to know if the $75 is worth it...
Old Sep 13, 2007 | 04:21 AM
B18C_EJ8's Avatar
If it's plastic vibrating, then no, dynamat on the trunk lid probably won't help....
You'll need to get in the back seat, crank up the tunes and find where the vibration is coming from. Then, using expanding foam (be careful with this stuff) or whatever other foam you can find, isolate the two panels from each other...
Old Sep 13, 2007 | 05:20 AM
candyman206's Avatar
Default Re: anyone with subs.. dynamat? (zeBRAHz)
I know in my 95 coupe it was the 3rd brake light plastic hitting the back glass.
Old Sep 14, 2007 | 06:08 PM
MinuteRice's Avatar
Default Re: anyone with subs.. dynamat? (candyman206)
Make sure all the screw and plastic clips are there before adding dynamat. just go through all the screws and tighten up every thing you can. If you have too, replace the push in's. If the interior parts are tight, nothing should rattle.
I would not use spray foam.
Old Sep 14, 2007 | 08:09 PM
B18C_EJ8's Avatar
Default Re: anyone with subs.. dynamat? (MinuteRice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MinuteRice &raquo;</TD></TR><TR><TD CLASS="quote"> I would not use spray foam. </TD></TR></TABLE>
Why's that? Enlighten us.
Old Sep 15, 2007 | 11:00 AM
MinuteRice's Avatar
Default Re: anyone with subs.. dynamat? (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Why's that? Enlighten us.</TD></TR></TABLE>
To me its just not a good idea to be going and spraying foam in between the panel and the metal. That stuff can get messy real quick. plus down the road, if and when these panels needed to be removed it make the removal process alot more difficult. The idea to use spray foam is not that bad of a idea, but it could go wrong very quickly. I think that other materials could be used to seperat the panels better, such as a piece of thin speaker box carpet.
Old Sep 16, 2007 | 08:09 PM
thekid03's Avatar
where are your subs mounted and which direction do they fire? this may give you some indication as to where the rattling is occurring but like the other guy said just turn it up fairly loud and walk around and look inside to determine where it's rattling. If you need to get a friend to put pressure on rear deck, side panels, trunk, etc. to try and locate the rattle.
Trunk kit will help but it depends on your listening style....might/might not solve the problem. I've got (2) 10w7's powered by an ARC 1500-xxk and mainly listen to EDM but even with everything other than my roof dynamated and a 2nd layer of dynamat in trunk I still get a couple rattles. I bought a couple door kits and cut 6x6" squares to affix to the sheet metal where the tail lights are located + removed the plastic on hatch and put more deadener there as well.
XYRS2LT
Feb 4, 2015 11:21 AM
toki
Sep 14, 2014 08:04 PM
JDMegCoupe
Audio / Security / Video
20
Sep 28, 2006 04:35 PM
96 SOHC VTEC
Jan 8, 2003 02:01 PM
MikeExt
22
Oct 10, 2002 01:59 PM
