antenna
Old May 16, 2013 | 07:35 PM
pservin89's Avatar
Default antenna
Where is the antenna on my 2002 acord at Iam trying to fix it I can any stations on my radio the tip where it gose into the radio came off how could I fix that with out taking the hole thing off
Old May 18, 2013 | 08:46 AM
HondaAccordKen's Avatar
Default Re: antenna
You could replace the plug. It's called a Motorola antenna plug and I've seen solder-less types. It's best soldered. Radio Shack used to carry both types. The center wire is usually very thin. it needs to be connect to the center pin and the shield needs to be connect to the mettle body or ground contacts of plastic connector. Best go to a good car stereo shop and get it soldered.
I believe cable runs to above head liner where there is a preamp above rear window. Could always find one in a bone yard.
Old May 20, 2013 | 07:45 AM
pservin89's Avatar
Default Re: antenna
Thank u for that that really helpful ill try both
97honda_accord
Mar 29, 2015 08:24 PM
kaotikvizion
15
Nov 5, 2013 07:44 PM
koumatae
Aug 2, 2012 12:53 PM
Luke G.
Apr 25, 2009 03:13 PM
Slipknt777
Aug 2, 2004 09:31 AM
