Another power door lock question/keyless entry
Subscribe
Jun 8, 2005 | 03:46 PM
Ok, for those that have installed a keyless entry system, how did you go about tapping the power door lock switch? the control unit and whatnot is in the door, so did you go through the door wiring harness? and that thing is a pain in the *** to get to.
any suggestions on how to tap switch wiring?
btw, 95 integra LS. thanks.
Reply 0
Jun 8, 2005 | 09:39 PM
you can catch lock and unlock wires in driver kick panel behind cruise control module theres two gray plugs behind module the one thats bigger is the plug with lock and unlock. lock is black with white stripe unlock is black with red stripe.
Reply 0
Jun 9, 2005 | 08:21 AM
Re: Another power door lock question/keyless entry (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">Ok, for those that have installed a keyless entry system, how did you go about tapping the power door lock switch? the control unit and whatnot is in the door, so did you go through the door wiring harness? and that thing is a pain in the *** to get to.
btw, 95 integra LS. thanks.</TD></TR></TABLE>kcem1 is correct........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcem1 &raquo;</TD></TR><TR><TD CLASS="quote">you can catch lock and unlock wires in driver kick panel behind cruise control module theres two gray plugs behind module the one thats bigger is the plug with lock and unlock. lock is black with white stripe unlock is black with red stripe.</TD></TR></TABLE> I will add, they are low current neg. (-) trip 94
Reply 0
Jun 9, 2005 | 10:13 AM
Re: (kcem1)
right on. got it in without a hitch. thanks.
Reply 0
Subscribe
