amplifier wiring
Old Jan 25, 2003 | 05:02 PM
duppykiller1's Avatar
Default amplifier wiring
I was thinking of wiring an amp but instead of using chassie for the ground, can I hook up both wires to the battery with fuses for positive and negative.
Also would I have to change the stock altinator for a 400 watt amp?
Old Jan 25, 2003 | 06:57 PM
EBP_SI's Avatar
Default Re: amplifier wiring (duppykiller1)
you could use the battery terminal as a ground but why would you want to? it's best to keep your wiring as short as possible.
Old Jan 25, 2003 | 10:06 PM
ratherbewalking's Avatar
you can run the ground to the battery. ive seen it done on high current wattage systems. supprisingly enuff there was no engine whine at all. i dont see the need to fuse a ground wire.
Old Jan 26, 2003 | 06:10 PM
Default Re: amplifier wiring (ratherbewalking)
thanks for the info but do I have to upgrade the altinator ?
Old Jan 26, 2003 | 08:27 PM
clm's Avatar
clm
Depends on how big your system is.
Old Jan 26, 2003 | 10:13 PM
abraunworth's Avatar
New User
Default Re: amplifier wiring (clm)
For 400 watts, I wouldn't worry about it. Your headlights may dim a bit on bass hits, but you don't need to wory about it. I had 2 300 watt amps in my civic with the stock alternator.
Old Jan 26, 2003 | 10:34 PM
funkylemons's Avatar
if anything, get a cap.. maybe a .5 farad..
DCRB
Audio / Security / Video
Jul 2, 2010 08:03 PM
91hatchproject
Mar 19, 2010 03:01 AM
import810
11
Mar 27, 2006 07:09 PM
TheKamikazeSquirrel
Jul 7, 2004 09:45 AM
IdotheSHOCKER
Jun 26, 2002 08:12 PM
