Amp wiring and rca question
Old Jul 31, 2004 | 08:03 AM
boostedcvc's Avatar
Default Amp wiring and rca question
I just finished installing and xtant a300 amp and a cheap little pioneer sub and am having trouble getting it to run. The amp has power and the speaker is hooked up correctly, but when you plug in the RCA's to either the amp or the back of the deck, instead of the sub working, the rear speakers stop working. any idea's on why thats happening? the deck is a jvc kd-s570. any help would be greatly appreciated.
Old Jul 31, 2004 | 08:25 AM
civicjester's Avatar
Default Re: Amp wiring and rca question (boostedcvc)
short in the deck or your using the wrong set of pre amp outs
Old Jul 31, 2004 | 08:31 AM
boostedcvc's Avatar
Default Re: Amp wiring and rca question (crxjester)
the preamp outputs are by stinger. I bought them just the other day to put the amp in. hope it's not a short in the deck!!
Old Jul 31, 2004 | 08:47 AM
no not the rcas.....how many sets of plugs do you have coming out of the back of your decj that you can plug rca's into?
Old Jul 31, 2004 | 08:56 AM
boostedcvc's Avatar
my bad, yeah I only have one set of preouts. They are also labeled rear, which would make sense why the rears aren't working if there is something wrong with them.
Old Jul 31, 2004 | 08:57 AM
that might be your problem you might want to look up the manual for your particular model to see the reccomendations of running a sub amp off of it
Old Jul 31, 2004 | 08:59 AM
boostedcvc's Avatar
i'm sure i dont have it anymore, but im sure a little internet searching can find it
Old Jul 31, 2004 | 10:46 AM
the best thing to do is go to the website of the company and get the exact specs on the deck you might have to run your back speakers off of one amp and split the rca signal to run your sub amp..ive heard that but never actually seen anybody do it for that reason....so leat me know what is going on ill try to help as much as possible
Old Jul 31, 2004 | 08:26 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcvc &raquo;</TD></TR><TR><TD CLASS="quote">my bad, yeah I only have one set of preouts. They are also labeled rear, which would make sense why the rears aren't working if there is something wrong with them.</TD></TR></TABLE> I have never heard or seen a HU that has internal amp cutoff when RCAs are pluged in, but I have seen amps that are screwed up and plugging the outputs of a HU into them will shut the speaker outputs of the HU down [shorting out] ,if the HU still works when RCAs are pluged into it but not to the amp, you can test the pre amp output of the HU by hooking up a small speaker to the RCAs ,pos. of speaker to RCA center pin,neg. of speaker to outside of RCA the sound will be very low, but if the preamp output and RCAs are good you will hear music, maybe unplug the rear speakers so you can hear better, if you can head something ,the amp or the sub is hooped.
hope this helps .94
Old Aug 1, 2004 | 07:33 PM
boostedcvc's Avatar
Default Re: Amp wiring and rca question (fcm)
thanks, I'll try that tomorrow!!
digital sol
Audio / Security / Video
Jul 8, 2013 09:20 AM
VTECth1s
23
May 26, 2011 12:10 PM
Civic Si Kid
Feb 28, 2009 07:42 PM
BiG_DeE
Jan 24, 2009 11:48 PM
Cody2289
14
Feb 11, 2008 09:28 AM
