amp wire problems, help me
Old Nov 4, 2002 | 01:01 PM
puddleofmudd's Avatar
Default amp wire problems, help me
I got subs installed a couple weeks ago, and today i decided to be a moron and try turning the subs around and putting them in the backseat. I didnt unplug the wire from the fuse box, and in the process of turning the subs around, and the positive and negative wires touched makin a spark. I went to look up at the fuse to make sure everything was ok. The glass inside the plastic thing that the wire runs through (i guess its the fuse with a case around it) had broken. How do i fix this?
Thanks for the help...
Old Nov 4, 2002 | 01:46 PM
Default Re: amp wire problems, help me (puddleofmudd)
bump
ive talked to a friend of mine, and he thinks all i need to replace is the fuse. will i have to buy another plastic case also, or will i be able to buy just a fuse?
Old Nov 5, 2002 | 06:35 PM
Ludester's Avatar
Should be able to get by with just a fuse unless the casing is cracked. But you could have blow a fuse on the amp too. check them all. good luck
Steven P
May 7, 2016 02:36 AM
AdventurousDude
Jun 5, 2008 10:30 PM
honda94accord
Audio / Security / Video
Aug 1, 2007 06:45 PM
Rhymenoceros
10
Oct 13, 2006 06:41 AM
Ronin Integra8
Jun 3, 2003 05:18 PM
