Amp wire to fuse?
Old Dec 14, 2004 | 03:08 AM
casmello's Avatar
Default Amp wire to fuse?
Ok, I totally can't rememer what the smallest wire is called that runs from your amp to your fuse or HU. Not the RCA wires, but my HU Pioneer DEH 1600 doesn't have a spot to clip this wire into, so I have to hook it up with one of the fuses in my box. I got both of the panels to show which fuse it what, but im not sure which one is goes into.
Left Fuse Box:
Sun Roof Motor
Power Seat REC
Power Seat Slide
Laf Heater
P/W Rear L
P/W Front R
Radio and Cigarette Lighter
Small Light and License Light
Interior Light and Courtesy Light
Power Door Lock
Clock Back Up
ABS MTR CHK
P/W Front L
P/W Back R
Right Fuse Box:
Starter Signal <--- I think this one is the one but I wanna double check.
FR Wiper
IG Coil
TUrn Lights
Back Up Light and Instrument Light
ACC Relay
RE Washer and Side SRS and Sun Roof Relay
ECU and Cruise Control
Day Light
R/C Mirror
Heater Control and A/C Clutch Relay and Cooling Fan Relay
SRS
Fuel Pump
Ok it was fun typing that now if anyone knows please let me know.
Thanks alot!
Old Dec 14, 2004 | 07:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: Amp wire to fuse? (casmello)
It sounds like the amp trigger wire, and your HU should have a blue/white, and or a blue, if both, use blue/white, if only one, use it, if amp only works when radio is on , [not CD] then you have the wrong wire or the proper one is missing, if so you can use the acc. freeplug in the fuse box, one of 3 or 4 freeplugs on fuse box, [ male spade term., like a speaker pos. term., inset into the box. 94
Old Dec 14, 2004 | 07:33 AM
casmello's Avatar
Default Re: Amp wire to fuse? (fcm)
My HU has 3 plugs.. 1 connector for the harness, 2 plugs for the RCA cables and 1 plug for the antenna. Nothing else, there should be a clip where you can put the end of the split wire but there is none, so I have to go threw the fuse, but it has to be the fuse so when you start you car it turns on... It worked with my jeep but it was a lot easier, because the fuses said exactly what they were.
Old Dec 14, 2004 | 07:59 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by casmello &raquo;</TD></TR><TR><TD CLASS="quote">My HU has 3 plugs.. 1 connector for the harness, 2 plugs for the RCA cables and 1 plug for the antenna. Nothing else, there should be a clip where you can put the end of the split wire but there is none, so I have to go threw the fuse, but it has to be the fuse so when you start you car it turns on... It worked with my jeep but it was a lot easier, because the fuses said exactly what they were.</TD></TR></TABLE>On the "connector for the harness" is there not any blue wires? if not and you have a Honda/Acura there are 2 "switched freeplugs on the fuse box, one is ign. the other is acc., use the acc. one so the ign. only has to be switched on to the acc. spot , [one click] 94
lilazndrag0n02
Feb 3, 2013 06:37 AM
lowandloud
Feb 12, 2012 06:06 PM
grape1161
Aug 30, 2009 07:59 PM
EliteCivicX
Apr 10, 2005 06:07 PM
casmello
Dec 13, 2004 04:26 PM
