amp question
Old Jan 4, 2006 | 10:38 PM
harley06's Avatar
Default amp question
what do i need so i can run 2 amps to my subs?
Old Jan 4, 2006 | 10:45 PM
JTTeG_X's Avatar
a distrobution block so you can split your power wire from the battery to both amps.
i believe stinger makes a "T" block. last ive seen them was at http://www.sounddomain.com for few bucks.
as for remote, just link them one to another.
ground; just add an additional terminal for the current grounding location you have now.
Old Jan 4, 2006 | 10:57 PM
harley06's Avatar
Default Re: (JTTeG_X)
on the remote wire what do i do, since its hooked up to one amp. what do u mean link them to one another. and what about the RCA preouts? which amp do i hook them to.
on 1 of my amps it has input and output rca preouts, so do i just hook it from the output to another amp?
Modified by harley07 at 12:22 AM 1/5/2006
Modified by harley07 at 12:25 AM 1/5/2006
Old Jan 6, 2006 | 06:01 AM
IHateJDM's Avatar
Default Re: (harley07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley07 &raquo;</TD></TR><TR><TD CLASS="quote">on the remote wire what do i do, since its hooked up to one amp. what do u mean link them to one another. and what about the RCA preouts? which amp do i hook them to.
yes, you can run rca's from one amp to another, and for the remote wire, get a t-tap and tap the new amp's remote wire into the existing one. Look on ebay for distribution blocks, I got one on there real cheap a few months back.
Old Jan 6, 2006 | 01:29 PM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: amp question (harley07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley07 &raquo;</TD></TR><TR><TD CLASS="quote">what do i need so i can run 2 amps to my subs?</TD></TR></TABLE>
WHY? (one amp per sub?) If so , Y-cable for RCA's , distribution block for power and ground , and just splice the remotes together.
Old Jan 6, 2006 | 08:55 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley07 &raquo;</TD></TR><TR><TD CLASS="quote">what do i need so i can run 2 amps to my subs?</TD></TR></TABLE>What kind of amps, make and model, a one to two splitter something like this.....
http://www.scosche.com/efx.asp...MW4BI
The grounds you just run one off each amp and ground them to the same place.
The amp control lead you can just daisy chain from one amp to the next.
The RCAs are a differant story, it will depend on the amp, and the HU you have, if the amp has a "L" input, [left input] you can switch it to that mode and just plug the RCAs into the left input of each amp, if not then the into one amp and out to the other. [daisy chain] will work, some HUs have a "mixed" or mono sub output, handy if using the "L" input mode. 94
Old Jan 7, 2006 | 10:11 AM
nsxxtreme's Avatar
Are you talking about strapping two amps to a sub?
If so your amplifier needs to be a mono amplifier.
Is it?
8YourV8
Audio / Security / Video
13
Dec 11, 2010 09:50 AM
philosofy1
Dec 18, 2007 02:12 PM
GZERO
Dec 26, 2005 09:52 AM
rollin92
19
May 28, 2005 10:27 PM
DownBoyDown
May 15, 2003 10:12 AM
