amp problem
Old Oct 7, 2007 | 06:27 PM
carlthecrx's Avatar
Default amp problem
so there is a problem with my amp.. it wont come on at all.. and i know its getting all the neccisary power ( i checked it with a meter )
but yeah, any suggestions?
Old Oct 7, 2007 | 06:40 PM
fcm's Avatar
fcm
Old Fart
Default Re: amp problem (carlthecrx)
What kind of fuse is in the power cable, [by the batt.]?
Have you checked the ground?
Where is the amp mounted and where is the ground cable connected?
Last but not least, what is the make and model of the amp? 94
Old Oct 7, 2007 | 10:37 PM
carlthecrx's Avatar
Default Re: amp problem (fcm)
good fuse, its getting power... its got a good solid ground... and its an old *** 4 channel MTX Audio..
Old Oct 7, 2007 | 11:47 PM
crux131's Avatar
Just a check, but is the remote wire hooked up/working correctly? Didn't see any mention of it.
Old Oct 8, 2007 | 07:14 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlthecrx &raquo;</TD></TR><TR><TD CLASS="quote">good fuse, its getting power... its got a good solid ground... and its an old *** 4 channel MTX Audio..</TD></TR></TABLE> Well 2 for 2 is not too bad, but I didn't ask if the fuse was good, I asked what kind it was, and I assume that when you say the ground is solid you checked it, but I also asked where it was connected?
One more question, what is the MTX amp driving, and please give me makes and models, including the model of the MTX amp. 94
Old Oct 8, 2007 | 08:12 AM
carlthecrx's Avatar
it was a problem with the amp.. i got a new one and it works fine, thanks
Old Oct 8, 2007 | 08:22 AM
fcm's Avatar
fcm
Old Fart
94
Old Oct 12, 2007 | 07:57 PM
slomx5's Avatar
Perhaps the leed that goes to the power terminal inside the amp is broken. Try taking it apart to see if it's anything obivious, since you have nothing to loose. Use your meter or a friends to check for continuity from where the feed wires go to where the circuit. I've also seen amps where a jumper simply broke, probably from vibration. I don't suppose this amp was hooked up to a 12" JL sub with a ported box that's been recarpeted has it?
Old Oct 12, 2007 | 09:04 PM
carlthecrx's Avatar
Default Re: (slomx5)
i took it apart, but i didnt see anything obvious, and i don't know **** about circuitry so i didn't mess with it, and close, it was 10" JL with a recarpeted ported box.... but yeah somebody stole all my **** and when i got it back from the cops the amp didn't work, so i dunno?
Old Oct 12, 2007 | 09:07 PM
carlthecrx's Avatar
Default Re: (carlthecrx)
damnit, patrick... i was like, "how the hell does this guy know everything about my system"... then i saw slowmx5....
Old Oct 13, 2007 | 08:23 PM
slomx5's Avatar
HAHAHA! Yea, you should have checked it with my meter. This sucks I can only type up 5 messages a day because of this trial stuff. My slo mx5 just got a little quicker; I washed it. Let me have your old amp, I'll probably fix it and use it in my car to drive the door speakers. That would be cool If it's repairable. Come check out miata.net!!!
Old Oct 14, 2007 | 07:34 AM
carlthecrx's Avatar
i tested it with a meter at the shop, but you can have it next time your in town... haha, no thanks i think i'll stick to honda-tech
Old Oct 14, 2007 | 07:17 PM
slomx5's Avatar
aw, come check it out. There's a lot more people and you can read how people get pissed because they ran 12PSI for 4 years and 40K miles and now there motor uses oil and is starting to loose compression. Funny, a honda makes more power off boost than a mazda, but the mazda will take a hell of a lot more abuse stock before kicken the bucket.
NewtoCivics
Audio / Security / Video
12
Jan 11, 2012 04:28 AM
muhaMan
Sep 14, 2007 06:48 PM
jli18
18
Jul 25, 2006 07:54 PM
2K GSR
Jan 15, 2004 08:46 PM
jamal-188
Jul 8, 2002 06:21 PM
