amp placement
Old Mar 25, 2003 | 02:19 PM
i's Avatar
i
Default amp placement
(sorry in advance if this has been posted recently)
wheres a good place to put an amp? i didnt want to drill any holes in my sub box or my panel or anything, so i attached it to a long peice of wood and wedged the other end under my box. seems to work alright, but i was thinking about getting a fan since summer is comin up, and i was told its better to have the amp on the side and have the air blowing over it.
what amp placement do you guys have? (please attach pics if possible)
Old Mar 25, 2003 | 02:40 PM
cd5_2NR's Avatar
Default Re: amp placement (i)
i'll post pics later on in the week..i recently mounted my amps on a 3 ft piece of wood and wrapped it with black carpet...then placed it on the back of my seat...i'll show pics when i can...i did have it under my seat..but i was tired of kicking the amp and seeing those damn wires...
[Modified by DRAG_ZERYONsi, 5:21 AM 3/28/2003]
[Modified by DRAG_ZERYONsi, 7:34 AM 3/28/2003]
[Modified by DRAG_ZERYONsi, 7:52 AM 3/28/2003]
[Modified by DRAG_ZERYONsi, 9:02 PM 3/28/2003]
Old Mar 25, 2003 | 03:09 PM
1BlackHatch's Avatar
Default Re: amp placement (DRAG_ZERYONsi)
How did you secure it to the seat back?
Old Mar 25, 2003 | 03:47 PM
i's Avatar
i
...i recently mounted my amps on a 3 ft piece of wood and wrapped it with black carpet..
you have the carpet <U>covering</U> the amps? does that cause any problems with overheating? and.. are these amps connected to your speakers or subs?
Old Mar 25, 2003 | 05:49 PM
vteg's Avatar
New User
I think he is saying that the board is wrapped in carpet with amps mounted on top.
Old Mar 25, 2003 | 07:39 PM
JOMO
Guest
Posts: n/a
Default Re: amp placement (vteg)
throw them in the trunk!
Old Mar 25, 2003 | 08:15 PM
xXxS_SxXx's Avatar
Default Re: amp placement (JOMO)
hahaha good one
Old Mar 25, 2003 | 08:55 PM
JOMO
Guest
Posts: n/a
Default Re: amp placement (xXxS_SxXx)
actually, it was not a joke!
Old Mar 25, 2003 | 10:54 PM
cd5_2NR's Avatar
i meant that the wood was covered it carpet..with the amps mounted in it...all the wires are hidden behind the wood and under the amp...
"how did i mount the wood"...you can either drill it straight through the rear of the seat...which i didnt do...i used brackets shaped like an L...and mounted it on the upper part of the seat...not on the back part of the seat...the top part of the seats close onto...the metal part...
[Modified by DRAG_ZERYONsi, 7:54 AM 3/26/2003]
[Modified by DRAG_ZERYONsi, 7:55 AM 3/26/2003]
Old Mar 26, 2003 | 12:10 AM
JOMO
Guest
Posts: n/a
your front seats???
Old Mar 26, 2003 | 12:52 AM
cd5_2NR's Avatar
naw..this is all behind my rear seats...i'll post pics sometime...
Old Mar 26, 2003 | 05:34 AM
Xsi's Avatar
Xsi
I always liked under the seats, not so easy to steal and they're kind of out of the way.
No so good heat-wise though, might need some fans.
[Modified by Xsi, 2:36 PM 3/26/2003]
Old Mar 26, 2003 | 05:39 AM
t0p_sh0tta's Avatar
Default Re: amp placement (Xsi)
What kind of car is that? I don't know of any amps that will fit under the seats of my EG.
Old Mar 26, 2003 | 03:24 PM
Xsi's Avatar
Xsi
Default Re: amp placement (t0p_sh0tta)
It's a G2 teg.
Theres not much space left, not enough for a capacitor either, had to panel beat the seat a bit
Old Mar 26, 2003 | 03:28 PM
t0p_sh0tta's Avatar
Cool
Nice Job
Old Mar 26, 2003 | 07:31 PM
JOMO
Guest
Posts: n/a
my amp is actually behind the passenger seat, i have it screwed into a floor mat and i can chuck it under the seat in a second, the floor mat has those 'spikes' on the bottom so it stays steady, it fils the speace nicely and i always pull the seat forward and look at it, and touch it, and play with it
Old Mar 26, 2003 | 09:07 PM
xXxS_SxXx's Avatar
actually i have both my amps mounted in my trunk its a good spot for them if you can secure them to something thats not going to break easy....plus it helps when making adjustments to the system
[Modified by xXxS_SxXx, 12:08 AM 3/27/2003]
[Modified by xXxS_SxXx, 12:09 AM 3/27/2003]
Boosted_MiniCRX
Feb 17, 2009 10:47 AM
97blackcoupe
Audio / Security / Video
May 11, 2004 02:25 PM
twinkie
Mar 4, 2003 04:08 PM
civicdee
Apr 25, 2002 08:54 PM
stevel
Jul 2, 2001 04:38 PM
