amp going into protect mode help!!!
Old Jan 22, 2006 | 02:01 PM
moores55's Avatar
Default amp going into protect mode help!!!
ok here is the deal i have a lighting audio amp i belive it's the 400 watt, i know its a 2 channel. ok so here is the deal i used to have 2 12's hooked up to it not briged and it worked fine but now i have one 12 hooked to it and when i turn it up on the deck its gose into protect mode. i have tried to adjust all of the settings and checked all wiringand its all good it only blows when briged i am useing low level inputs and my amp wire is 0 gauge any idea why this is happening i cant figure it out. thanks guys
Old Jan 22, 2006 | 03:23 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: amp going into protect mode help!!! (moores55)
what kind of sub are you running? we need a little more info to help you out.
Old Jan 22, 2006 | 07:04 PM
moores55's Avatar
Default Re: amp going into protect mode help!!! (wrx-killer)
sorry i have a pioneer 12 800 watt max.
Old Jan 22, 2006 | 08:43 PM
zumiez007's Avatar
sounds like your getting clipping by having the gain set too high. or, one of your connections is incorrect, like the the positive speaker wire is touching the negative speaker wire some place.
Old Jan 22, 2006 | 08:57 PM
LSRracing95's Avatar
Default Re: amp going into protect mode help!!! (zumiez007)
im gonna have to say the same thing.. try turning the gains down.. use volume before you start upping the gain. lightning audio amplifiers are pretty much a joke, so id also invest in a better amplifer.. and a better sub at that.
ODbuilt
Audio / Security / Video
Apr 27, 2014 11:43 PM
tram7128
31
Dec 7, 2010 12:56 PM
oOJ-GrindOo
10
Oct 21, 2004 09:19 PM
SIReg9
15
Mar 8, 2004 06:18 PM
brickonwheels
Jan 12, 2004 09:33 PM
