amp always on?
Old Apr 10, 2007 | 12:55 PM
flashintheleather's Avatar
Default amp always on?
Hi guys. I recently put my subwoofer back into my car after about a year of being without it. Its a JL 10w7 with a JBL 600.1 amp. It is hooked to an Alpine 9857 hu. From the looks of it I have everything connected correctly but the light on the amp is on all the time, not matter if the hu is on or not. Is this supposed to be this way? I have the remote turn on connected to the blue/white wire of the hu harness which is supposed to be the remot wire. Could it be a bad ground, since thats the only thing i can come up with. Thanks.
Old Apr 10, 2007 | 02:44 PM
tha_badguy's Avatar
are you sure you have the right remote wire from the deck?
sounds like u have a constant instead
Old Apr 10, 2007 | 03:32 PM
Default Re: (tha_badguy)
thats what i thought too, but i checked the wiring diagram and it tells me that white/blue is the remote, unless im misreading it, which wouldnt be a surprise. ill look at it again, thanks.
Old Apr 10, 2007 | 04:24 PM
fcm's Avatar
fcm
Old Fart
Default Re: (flashintheleather)
Disconnect the amp control lead at the amp, if amp light goes out, pull the HU and see what you wired the amp control lead to, you are correct it should be the blue/white, [the blue is power ant.] 94
Old Apr 10, 2007 | 04:46 PM
Default Re: (fcm)
problem solved. i disconnected everything at the amp and reconnected it and everything was better then. must have had the power lead loose or something. anyway, thanks for the help.
97civicB18C
Audio / Security / Video
15
Mar 5, 2007 10:19 AM
HBK
Oct 5, 2006 05:04 PM
Myh4tch
Nov 24, 2004 07:11 AM
Filliam H. Muffman
Apr 18, 2003 11:37 PM
