ALPINE SETUP HELP
Old May 10, 2007 | 09:59 AM
manchester8's Avatar
Default ALPINE SETUP HELP
I have a 98 honda accord v6 sedon.......
i have alpine CDA-9883 HU
Clarion EQS746 - Clarion 7-Band Rotary Equalizer (any idea on this one)
6x9 three way 250 watt each for the back (alpine
For the front did not get nothing yet (going alpine)
SUB Alpine SWR-1042D - Alpine 10" Type R 1500W Dual 4 Ohm Subwoofer...Thinking for getting two, maybe one..
AMP this is where i am lost...
should i get two amp what type should i get?
Capacitors should i get two if i get two amp? what type is good.
thinking about getting a Optima Yellow Top battery
what type of wires should i get?
Old May 10, 2007 | 11:45 AM
suspendedHatch's Avatar
Default Re: ALPINE SETUP HELP (manchester8)
You don't need a capacitor. You don't need a battery unless yours is bad or has been discharged and recharged several times.
You NEED an amp to power a sub. First figure out what the rms of that sub is, then get an amp that runs close to that rms at 4 ohms. If you're running one sub, get a mono amp. Two subs, get a 2 channel.
You need an amp power kit and RCAs. You also need a professional to install this for you. They should be able to help you pick out what amp based on your budget and needs.
Freezen
Audio / Security / Video
Feb 11, 2009 12:25 PM
845_dapek
Dec 1, 2006 08:57 PM
vivaladan89
May 18, 2006 10:56 AM
MilanoCivic97
Apr 11, 2006 08:27 PM
happyman12
Feb 18, 2004 04:01 PM
