Alpine.....i-Personalize Question???????
Old Jun 15, 2003 | 08:25 AM
Synergy001's Avatar
Default Alpine.....i-Personalize Question???????
Does anybody here with i-Personalize have EQ and Crossover Settings saved? I made a mistake to disconnect my battery to clean the terminals and then my settings that took me a long time to configure got erased. If anybody has a setting with good mids & highs, and excellent bass could you guys give me the configurations or if you have it on a disc or on your computer could you please send it to me. TIA!!
Old Jun 15, 2003 | 10:21 AM
Synergy001's Avatar
Nobody???
Old Jun 15, 2003 | 08:14 PM
t0p_sh0tta's Avatar
Default Re: (Synergy001)
Have you checked out the i-personalize section of alpine's website?
Old Jun 15, 2003 | 08:24 PM
HiRevn's Avatar
Default Re: (t0p_sh0tta)
That thing is pretty complicated. I still haven't figured out how to tweak that thing. But like top shotta said, go to the Alpine website go to the i-personalize link, it should make it a little easier.
Old Jun 15, 2003 | 09:44 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: (HiRevn)
I would start with small tweaks. Unfortunaly each persons set-up will vary so what has good mid/high in one car may sound horrible in another.
This site is very informative on equalization:
http://www.recordingeq.com/EQ/req0900/primer.htm
Old Jun 15, 2003 | 10:12 PM
vteg's Avatar
New User
Default Re: (arizsun21)
Once you setup i-personalize to your liking, you can burn the settings to disc, and have them forever. I would learn how to setup your stereo without using it, if you are a tweaker. I tried i-personalize before I learned how to use the stereo controls. I have never used it again.
Thanks for that link. It is really cool.
Old Jun 16, 2003 | 08:15 AM
Synergy001's Avatar
I ALREADY KNOW about the i-Personalize section on Alpine. I just wanted to know if anybody had some that I can download into my unit. I know that you can burn a disc and have the settings forever but I had adjusted it manually so I couldn't burn it. Thanks anyways
Old Jun 16, 2003 | 09:08 PM
Richard.'s Avatar
heh, that **** is too complicated.. i'm looking at it right now..i dont understand what any of that stuff does, o well.. i like the way my system sounds liek that without it.
Old Jun 17, 2003 | 12:56 AM
vteg's Avatar
New User
You should do your own anyway. For example my system has hexes in kicks(front channel), kicker midbasses in door(rear channel) and a ported 12 with 1000 watts. Front stage is 300-400 watts total. Unless you setup is very similar to mine, it probably would not sound good at all.
Old Jun 19, 2003 | 09:56 PM
ArizSun21's Avatar
Default Re: (Spoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon &raquo;</TD></TR><TR><TD CLASS="quote">heh, that **** is too complicated.. i'm looking at it right now..i dont understand what any of that stuff does, o well.. i like the way my system sounds liek that without it.</TD></TR></TABLE>
The main thing I got out of the website is to cut frequencys instead of boosting them. This will help the SQ in a big way!!!
Shaynepolevault
May 12, 2008 06:56 AM
paulzy
Welding / Fabrication
May 5, 2006 08:45 AM
SEFIxCivic
May 12, 2003 06:21 PM
hatchback
Oct 18, 2002 02:05 AM
