Alpine Headunit
Old Jul 31, 2003 | 06:07 AM
civicracer99's Avatar
Default Alpine Headunit
I've had this alpine headunit for about 2 years now, and for the past 6 months the Cd player has been skipping everytime I hit a bump, and it never used to do that. I used a cd cleaner on it, but that didn't work. Does anyone know how I can fix it, or do I just have to get a new one? Thanks
Old Jul 31, 2003 | 08:06 AM
Torridcivic's Avatar
Default Re: Alpine Headunit (civicracer99)
The fact that this is new either means that the unit changed or the enviornment changed. In other words if you remounted it and that is what caused it to start to skip then try remounting it again. If you have not remounted it then that means that something happened in the unit itself. Eitherway I would suggest that you try to remount it get it as tight as you can. There is built in skip protection so the tighter the mount the more effective that protection can be.
Old Jul 31, 2003 | 02:33 PM
Synergy001's Avatar
Default Re: Alpine Headunit (Torridcivic)
I think you should remount it again because the vibration might have loosened it.
Old Aug 3, 2003 | 08:52 AM
shipsaeki's Avatar
Default Re: Alpine Headunit (Synergy001)
does it sometimes shut off and come on quickly right where the song left off when you hit a hard enough bump? same thing happened to me. If you have an amp and a remote wire from the headunit... check all the wires. also be sure to double check the ground wire on the amp. if you dont have one, check your powersource behind the headunit.
Old Aug 3, 2003 | 09:16 AM
Default Re: Alpine Headunit (shipsaeki)
That same thing just happened to me, one night at like 2 I was leaving a friends house and every little bump I hit my h/u would shut off and then turn back on, maybe like 10 times in 5 minutes. But It hasn't happened again since then. Crazy
Old Aug 3, 2003 | 10:31 AM
GSteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracer99 &raquo;</TD></TR><TR><TD CLASS="quote">I've had this alpine headunit for about 2 years now, and for the past 6 months the Cd player has been skipping everytime I hit a bump, and it never used to do that. I used a cd cleaner on it, but that didn't work. Does anyone know how I can fix it, or do I just have to get a new one? Thanks</TD></TR></TABLE>
what model is it?
Old Aug 3, 2003 | 12:48 PM
J^M^'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Torridcivic &raquo;</TD></TR><TR><TD CLASS="quote">That same thing just happened to me, one night at like 2 I was leaving a friends house and every little bump I hit my h/u would shut off and then turn back on, maybe like 10 times in 5 minutes. But It hasn't happened again since then. Crazy</TD></TR></TABLE>haahahahahaha its called 'drunken bumping' you were toasted man! my set caught fire one night i swear!
Old Aug 3, 2003 | 01:54 PM
rjr162's Avatar
Default Re: Alpine Headunit (Jomo3)
try using one of those compressed air cans on it. Sometimes if the lens is dirty/dusty it will end up being more sensitive to bumps
MeanusGeneus7
May 16, 2011 03:25 AM
SiKnezzALLmotor
Northern California (Sales)
Sep 1, 2009 10:58 AM
RotaryPWR
Audio / Security / Video
Jun 13, 2008 08:19 AM
92-LS-Civic
Oct 7, 2005 09:06 AM
RideOrDie
Oct 4, 2005 06:07 PM
