Alpine guru's need your help!!
Old Dec 16, 2003 | 07:06 AM
unltdacc12's Avatar
Default Alpine guru's need your help!!
Allright heres the situation. My 7995 only plays the right channel when listening to CD's or MP3's. When using the aux or radio it plays both the left and right channels. Im guessing that it has something to do with the laser.
Has this happened to anybody else? Are there any easy fixes? I was thinking about opening it up and taking a peak. Any help would be much appreciated. Thanks
Old Dec 16, 2003 | 08:07 PM
95slowmattic's Avatar
Default Re: Alpine guru's need your help!! (unltdacc12)
i sell that deck. well did. we ran out. anyway, make sure that all of the settings on the deck are at zero when playing a cd or radio. the settings can change between those sources. also make sure the rem. wire that you used is not the power ant. wire. if not any of these, hold down the function botton and scan through the menu with the band or tracking button and make sure nothing "extra" is on or anything.
Old Dec 17, 2003 | 05:41 AM
rjr162's Avatar
Default Re: Alpine guru's need your help!! (95slowmattic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95slowmattic &raquo;</TD></TR><TR><TD CLASS="quote">i sell that deck. well did. we ran out. anyway, make sure that all of the settings on the deck are at zero when playing a cd or radio. the settings can change between those sources. also make sure the rem. wire that you used is not the power ant. wire. if not any of these, hold down the function botton and scan through the menu with the band or tracking button and make sure nothing "extra" is on or anything.</TD></TR></TABLE>
If is was the p. antenna wire and he's using an amp, he wouldn't hear any audio at all. If you *are* running an amp though, please let me know. There's a couple more things to look at.
My guess is either the balance is set to the right side on CD, but I don't think it remembers that as a setting it keeps different between radio and CD (as mentioned above, the radio can remember different settings for different sources), or, as is most cases where a whole side goes out, it is infact something in the unit its self. It's something in the CD decoder board area, before the amp & preamp.
Old Dec 17, 2003 | 07:02 AM
unltdacc12's Avatar
Default Re: Alpine guru's need your help!! (rjr162)
Ive checked all the settings (balance and fader), and everything looks normal. I am using 1 four channel amp for interior speakers, and 1 two channel amp for the subs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">
as is most cases where a whole side goes out, it is infact something in the unit its self. It's something in the CD decoder board area, before the amp & preamp.</TD></TR></TABLE>
Thats what i was thinking. Im wondering if i open it up, maybe itll be something obvious, like a loose plug, or something. Thanks for the input
92-LS-Civic
Audio / Security / Video
Oct 7, 2005 09:06 AM
94CIV
12
Apr 4, 2005 11:58 PM
.RJ
Dec 26, 2004 06:54 PM
ace42004
Jul 31, 2004 05:21 PM
