Alpine deck install in gsr!
Old May 8, 2004 | 03:50 PM
fuck honda-tech's Avatar
Default Alpine deck install in gsr!
HEy whats up everyone i just purchased a cda9815 yesterday, to make a long story short. I have never installed a stereo, and my friend convinced me to cut off the stock harness. The stock harness is off now so this **** is pretty N**ga rigged now after i found out ur suppose to leave it on. Any way i just decided to connect the cut wires that connected to the stock harness and hook those up to the alpine harness directly. I plugged most of the wires in correctly from an online diagram. Just need to know which wires from the alpine harness mate with the stock harness colors:
Yellow/green wire = alpine?
Red/black wire = alpine?
White/blue wire = alpine?
Alpine harness colors plug into?:
Yellow= stock?
and the dimmer= stock ?
Thanks for reading and hopefully i get this in tonight!
Old May 8, 2004 | 05:47 PM
Default Re: Alpine deck install in gsr! (DankgsR)
help??
Old May 8, 2004 | 07:03 PM
Old May 8, 2004 | 07:10 PM
shyboy817's Avatar
hmmm, http://www.the12volt.com look for wiring diagram tells u exactly what color is which..
Old May 8, 2004 | 07:28 PM
Default Re: Alpine deck install in gsr! (shyboy817)
thanks
Old May 8, 2004 | 07:36 PM
hmm that websites kinda weird i logged on and everything and it still will not let me view it ."?
Old May 8, 2004 | 07:47 PM
EBP_SI's Avatar
my advice. spend the $5 on the adapter harness for these reasons.
1.) much easier to work on as you jsut have a couple of plus with about 6" of wires. you can put them together sitting in the couch if you want.
2.) you can put your car back to stock if you want by simply unplugging the adapter and plugging the stock plug into the stock deck.
3.) you dont have to worry about what the wire colors are. the harness will have all teh wires labeled so its a lot harder to mess something up.
oooops....didn't read the part about already cutting it off. if you've got the room to do so i'd reattach the stock one.
Old May 8, 2004 | 07:50 PM
Default Re: Alpine deck install in gsr! (EBP_SI)
thats what i was gonna do but i only got a couple left
Old May 8, 2004 | 07:53 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DankgsR &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was gonna do but i only got a couple left </TD></TR></TABLE>
yeah but you dont know what those wires are for so which one is gonna be faster
Old May 8, 2004 | 08:00 PM
1-800 call a homie cuz im getting off work.. thanks for the help peepz
Old May 10, 2004 | 06:47 AM
HiRevn's Avatar
My OEM wiring harness was all butchered up from a previous install. I cut what was left of the OEM harness and wired the Alpine harness directly to it. (I have a CDA-9813) Depending on what you're running you may have to hook it up differently. Since the 9815 has the built in amp, you're supposed to hook it up straight to the battery (just like an amp) I didn't hook mine up that way because I have a 5 channel amp that everything's running through. I spoke to Alpine customer service and they said that's fine, so technically, I'm making use of the built in amp.
nizubster
Audio / Security / Video
Jul 13, 2013 11:49 AM
OBDII Integra
13
Nov 23, 2010 07:13 PM
MilesG
18
Dec 28, 2008 05:29 PM
RTW DC2R
Dec 31, 2004 04:58 PM
EFing8
Nov 13, 2002 08:08 PM
