Alpine CDA-7894 Skipping
Old Jan 29, 2005 | 02:09 AM
Uneekpinoysk8er's Avatar
Default Alpine CDA-7894 Skipping
i did a search and read about CD players skipping and what not over the slightest bumps and most of you guys suggest to get a lense cleaner. well my Alpine CDA-7894 currently skips like crazy even over the littlest bumps. is the cd lense cleaner the only thing that works? is there any thing else i can try to do that you guys can suggest??
Old Jan 29, 2005 | 05:03 AM
HiRevn's Avatar
Default Re: Alpine CDA-7894 Skipping (Uneekpinoysk8er)
I think the problem you are having is beyond just cleaning the lense. If you are still under warranty, pull it out and have it checked out.
Old Jan 29, 2005 | 06:34 AM
its actually not under warrenty anymore. everything on it works fine, its just that for some reason when i hit bumps or bumpy roads it tends to skup the CD thats playing. what could be the worse case senario and how much am i looking to spend to have it fixed??
Old Jan 29, 2005 | 07:05 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uneekpinoysk8er &raquo;</TD></TR><TR><TD CLASS="quote">its actually not under warrenty anymore. everything on it works fine, its just that for some reason when i hit bumps or bumpy roads it tends to skup the CD thats playing. what could be the worse case senario and how much am i looking to spend to have it fixed??</TD></TR></TABLE>WCS.... would be that you will have to pull it and have it cleaned and the lens realigned, that said, by far the biggest cause of CD HU skipping is, THE HU IS NOT MOUNTED PROPERLY, and in most cases its no back brace for the HU, a CD HU must be mounted solidly into the dash for the CD transports suspention to work. If your HU does not have a back brace, [so easy to do on a Honda/Acura] then try that first. Nothing will knock a lens out of wack better then a HU with no back brace, letting it bounce around, and all it takes is one good jolt, [ that pothole you didn't see] 94
Old Jan 29, 2005 | 08:05 PM
Default Re: Alpine CDA-7894 Skipping (fcm)
any other suggestions. and also do you know where i can send my headunit too, some where in socal.
Old Jan 30, 2005 | 02:46 AM
ttt
Old Jan 30, 2005 | 06:31 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uneekpinoysk8er &raquo;</TD></TR><TR><TD CLASS="quote">any other suggestions. and also do you know where i can send my headunit too, some where in socal.</TD></TR></TABLE>Sorry don't know, but the best place would be an Alpine warranty depot, you should be able to find one from http://www.alpine.com or just ask at your local Alpine dealer 94
Old Jan 31, 2005 | 11:15 PM
em1 Ziggy's Avatar
hey its me fritz! hahaha cool... get compressed air.. and stick the straw inside and air the dust out.. ;D
Old Feb 1, 2005 | 06:54 AM
fcm's Avatar
fcm
Old Fart
Default Re: Alpine CDA-7894 Skipping (eK Ziggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK Ziggy &raquo;</TD></TR><TR><TD CLASS="quote">hey its me fritz! hahaha cool... get compressed air.. and stick the straw inside and air the dust out.. ;D</TD></TR></TABLE>No do not use compressed air, you can damage the unit 94
Old Feb 1, 2005 | 02:54 PM
okay heres an update, i tried a LASER CD LENS CLEANER and that didtn work at all, so now im going to ship the headunit in for repairs. hoepfully all goes well after that.
2nd_Gen
Audio / Security / Video
Aug 27, 2005 08:48 AM
UnionCity LS
Jan 18, 2005 01:48 PM
HAcEx01
Jan 17, 2005 05:14 PM
Home Skillet
Oct 18, 2004 12:01 PM
jamie_honda_08
Oct 11, 2004 03:33 PM
