alarm led?
Old Mar 11, 2007 | 12:03 AM
89hatcher's Avatar
Default alarm led?
is the light suppose to be flashing after the alarm is disarmed? cause mines flashes when i arm it and disarm it. what seems to be the problem?
Old Mar 11, 2007 | 07:19 AM
B18C_EJ8's Avatar
Is it flashing or on solid?
Old Mar 11, 2007 | 08:29 AM
fcm's Avatar
fcm
Old Fart
Default Re: alarm led? (89hatcher)
Ditto the above, and what is the make and model of the alarm? 94
Old Mar 11, 2007 | 12:02 PM
89hatcher's Avatar
its flashing and its a viper 5002
Old Mar 11, 2007 | 08:06 PM
fcm's Avatar
fcm
Old Fart
Default Re: (89hatcher)
ARE you sure you have the LED plugged into the correct port on the alarm brain?
It should be next to the starter cut leads, a blue port, on the same side as the parking light jumper access door.
The other possibility is, if when you arm the alarm the LED flashes at a rate of about ones a second, and when you disarm it it flashes twice as fast, you are in passive arming mode, the alarm will arm 30 sec. after ign. is turned off and door is opened and closed. 94
ukdmtony
Audio / Security / Video
Feb 13, 2021 09:38 AM
OOOtony
Mar 27, 2010 08:44 AM
Hanmin
Nov 29, 2007 11:19 AM
Spence
Aug 12, 2004 11:50 PM
eL
Jun 27, 2004 07:39 AM
