alarm keeps going off after engine bay degrease
Old Dec 13, 2004 | 11:18 AM
EK k kay's Avatar
Default alarm keeps going off after engine bay degrease
I degreased and sprayed down my engine bay yesterday. I covered the alternator distributor, sensors on throttle body, battery, fuse box, and the alarm speaker. After foaming it and spraying it down my alarm went off and would not turn of via the remote nor would it go into valet mode via the button and key turned to on. I disconnected the battery and surely it went off. Now when I hook it back up the alarm goes off and still wont turn off. I checked the fuses and they were all good. I'm thinking that some water got into the fuse holder thats hooked up to the main power cable going to the battery because I didn't cover that up. So I pulled that fuse and let it dry overnight. Now this morning I go to put the fuse back in and it still goes off. What should I do?
Old Dec 13, 2004 | 02:31 PM
EK k kay's Avatar
Default Re: alarm keeps going off after engine bay degrease (chowmien)
Anyone?
Old Dec 13, 2004 | 05:45 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">Anyone?</TD></TR></TABLE> Try turning on the ign. leave it on then install the fuse. BTW the fuse for the alarm, and power for that matter should be inside the car. 94
Old Dec 13, 2004 | 07:56 PM
EK k kay's Avatar
Default Re: alarm keeps going off after engine bay degrease (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Try turning on the ign. leave it on then install the fuse. BTW the fuse for the alarm, and power for that matter should be inside the car. 94</TD></TR></TABLE>
Turn on the ignition as start the car? Or turn it two clicks to the on position?Well for my alarm there's one 15a fuse right by the battery connected to the alarms power source. Then there's two other fuses right by the alarm brain, one which is another 15a which is also connected to the alarms power cable and the other is a 10a which I don't know what it's for. CarToys did the crappy install. My car was in ther possession for no more than 40 minutes during the install. They left the antenna by the pedals giving me almost no reception
Old Dec 13, 2004 | 09:13 PM
EK k kay's Avatar
Anyone else?
Old Dec 14, 2004 | 07:03 AM
fcm's Avatar
fcm
Old Fart
Turn on the ignition as start the car? Or turn it two clicks to the on position?Well for my alarm there's one 15a fuse right by the battery connected to the alarms power source. Then there's two other fuses right by the alarm brain, one which is another 15a which is also connected to the alarms power cable and the other is a 10a which I don't know what it's for. CarToys did the crappy install. My car was in ther possession for no more than 40 minutes during the install. They left the antenna by the pedals giving me almost no reception </TD></TR></TABLE> Two clicks not running, although that would work also, and you may have to reprogram the remotes 94
Old Dec 14, 2004 | 12:14 PM
EK k kay's Avatar
Thanks for the help. I guess after 2 nights of letting it sit, it dried out and works now.
Larry_Civic
Honda Civic (2001 - 2005)
May 5, 2018 09:09 AM
Ruben19
Audio / Security / Video
Dec 12, 2007 05:10 AM
mhz2010
Jan 17, 2007 05:26 PM
Akura
Jul 20, 2004 06:07 AM
