Alarm install
Old Sep 5, 2004 | 08:33 AM
carracr625's Avatar
Default Alarm install
I am about to install an alarm in my 91 civic hatch. Before anyone bashes me & tells me to have it profesionally installed, this is not the first alarm I've installed. Now, my question is, where should I mount the brain for the alarm? I have always mounted it under the dash somewhere on other cars that I've worked on. The problem I see with my hatch is there is very limited room under there, and I don't want it to be easily accessible to would be theives. I'm considering under the seat, but again that seems like if the thief looks under there he'll see it. Any advice on some stealth mounting spot? I want to try to keep it near the front do to all of the wiring, but I'll consider all suggestions.
Old Sep 5, 2004 | 08:35 AM
carracr625's Avatar
Default Re: Alarm install (carracr625)
Also, this alarm is the first I've installed with a glass break sensor. Where should I mount the microphone so that it will cover the whole car?
Old Sep 5, 2004 | 10:54 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carracr625 &raquo;</TD></TR><TR><TD CLASS="quote">I am about to install an alarm in my 91 civic hatch. Before anyone bashes me & tells me to have it profesionally installed, this is not the first alarm I've installed. Now, my question is, where should I mount the brain for the alarm? I have always mounted it under the dash somewhere on other cars that I've worked on. The problem I see with my hatch is there is very limited room under there, and I don't want it to be easily accessible to would be theives. I'm considering under the seat, but again that seems like if the thief looks under there he'll see it. Any advice on some stealth mounting spot? I want to try to keep it near the front do to all of the wiring, but I'll consider all suggestions.</TD></TR></TABLE> Mount alarm above and behind glovebox.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carracr625 &raquo;</TD></TR><TR><TD CLASS="quote">Also, this alarm is the first I've installed with a glass break sensor. Where should I mount the microphone so that it will cover the whole car?</TD></TR></TABLE> Mount mic. high, front and center on dash. 94
Old Sep 5, 2004 | 08:40 PM
Goatsterrman's Avatar
Default Re: Alarm install (fcm)
Make sure and take the time to hide the wires as well. It does no good to have the brain well hidden and have obvious aftermarket wires everywhere.
Old Sep 6, 2004 | 08:04 AM
carracr625's Avatar
Thanks guys...its going in today!
Old Sep 13, 2004 | 11:07 AM
carracr625's Avatar
Default Re: (carracr625)
I had to bring this back up because there is simply nowhere to mount this thing. There is not enought space behind or above the glovebox. And for that matter, I can't find anywhere to mount it under the dash @ all. I removed pretty much the entire dash w/o any luck finding any free space. Anyone have alternate ideas? I'm stuck here! The only place I can think of is under one of the seats, but I know that wouldn't be a great place do to its easy accessibilty.
HELP me out guys!
Old Sep 13, 2004 | 11:49 AM
Miss Green-Eyes
Guest
Posts: n/a
Can you actually install it within your glovebox at worst case scenario?
Old Sep 13, 2004 | 03:11 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carracr625 &raquo;</TD></TR><TR><TD CLASS="quote">I had to bring this back up because there is simply nowhere to mount this thing. There is not enought space behind or above the glovebox. And for that matter, I can't find anywhere to mount it under the dash @ all. I removed pretty much the entire dash w/o any luck finding any free space. Anyone have alternate ideas? I'm stuck here! The only place I can think of is under one of the seats, but I know that wouldn't be a great place do to its easy accessibilty.
HELP me out guys! </TD></TR></TABLE> There should be lots of room for it above air intake duct behind glovebox or behind drivers kick panel. 94
Old Sep 13, 2004 | 03:54 PM
Boxcar's Avatar
Default Re: (fcm)
I have installed many alarm systems and i have never rain in to the problem of no room to mount the brain?
Old Sep 15, 2004 | 12:31 PM
Yeung's Avatar
Default Re: (Boxcar)
the brain is so small that you shouldn't have problem hiding
Old Sep 15, 2004 | 02:39 PM
CarAudioPro's Avatar
well you can put it anywhere you want. if you install it correctly you could set it on the floor of the car in plain view and a theif stull couldn't get into the car without it going off.
rancidhooligan
Audio / Security / Video
Nov 14, 2007 05:02 AM
danelot
11
Mar 17, 2003 05:07 PM
superfuji57
18
Dec 9, 2002 09:41 PM
Alexander
11
Apr 4, 2002 08:32 AM
indy
17
Jul 12, 2001 08:25 PM
