alarm help
Old May 6, 2007 | 04:47 AM
wreckeddc4's Avatar
Default alarm help
just installed a compustar 2w900fm alarm in my 99 gsr and it dosent work. when i turn the car on the doors lock and when i turn it off they unlock.compustar instructions suck i cant understand them at all, i have 12v constant, ground, siren, parking lights, ignition input, door and hood pin, and power locks wired up, its supposed to chirp into program mode after turning the key on and off 5 times but i get nothing,what could be wrong? i already tried another brain and that was the same please help!!!
Old May 6, 2007 | 07:28 AM
suspendedHatch's Avatar
Default Re: alarm help (wreckeddc4)
When you say it doesn't work, do you mean it doesn't respond to the transmitter?
What do you have the ignition input wired up to?
Old May 6, 2007 | 07:35 AM
fcm's Avatar
fcm
Old Fart
Well it sounds like you have the door locks wired properly, [ign. controlled door locks are working] not sure why the are programed on, factory default is off.
You do not use the key to get into option program mode.
Ign. controlled door locks are in "Programming Menu #2 (Security Options)" 2/5.
Turning the ign. key on and off 5 times is used for programing the remotes, putting system into valet mode, and emergency override.
You may be turning the key on and off, [leaving it on the 5th time] too fast or too slow, it also has to be done uniformly, [evenly] Hint... after the first time you turn it to run, [ign.] only turn it back to acc., not all the way back off.
Do you not have the Installation Guide and the User Guide?
What other problems are you having?
Where did you get the Compustar?
I have installed more then a few Compustars, and I know option programing is a bit of a pain for the first timer when not using the programmer, but if you read the instruction it's not that hard.
Feel free to IM me if you need more help. 94
Old May 6, 2007 | 09:06 AM
wreckeddc4's Avatar
Default Re: alarm help (suspendedHatch)
it dosent respond at all, the remote does nothing, the ignition sensing wire is hooked into the blk/yellow wire in the igniton harness that is 12v keyed and when cranking
Old May 6, 2007 | 09:51 AM
Triple check the antenna.
Old May 6, 2007 | 11:16 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
It sounds like the controlers are not programed. They do not come pre-programed to the brain.
Old May 6, 2007 | 11:44 AM
fcm's Avatar
fcm
Old Fart
You have an IM. 94
tobytigger
Aug 16, 2012 09:15 PM
importdude2000
Audio / Security / Video
12
Jun 20, 2011 06:54 PM
jdmer329
Oct 10, 2010 08:35 AM
djbrandonr
Nov 19, 2006 04:59 PM
