alarm flashing lights problem , HELP!!
Old Sep 22, 2005 | 05:16 PM
sparta904's Avatar
Default deleted
deleted
Old Sep 22, 2005 | 06:18 PM
foz's Avatar
foz
Default Re: alarm flashing lights problem , HELP!! (sparta904)
+ flashing lights or (-) ?
what's the output of your unit?
are using some form of meter to test the wires or just hoping that they work?
Old Sep 22, 2005 | 09:27 PM
foz's Avatar
foz
if it's a negative output, then it's not going to work when you need a + pulse, and just trying wires, and not testing is just stupid. quit now and let a professional take over.
Old Sep 23, 2005 | 09:33 AM
foz's Avatar
foz
Default Re: alarm flashing lights problem , HELP!! (foz)
If you knew what the output was you would know wether or not you would need a relay, and if you tested the wire you would know what you required, any wire GUIDE is simply that a guide to help you test and find the wires that you need.
installing anything in a car by just hooking up wires and hoping they are right is incredibly stupid, at worst you should at least be using a test light to find out what wires are what ... if you can't figure out the output of the unit and are uncapable of testing the wires you are connecting to, then you my friend have no business installing an alarm in any car...
Old Sep 26, 2005 | 06:54 AM
B18C_EJ8's Avatar
Okay. Get a test light, and put the clip to ground, and touch the probe to the light flash output on the alarm. Then press your lock button on the remote. If the light in the test light illuminates, then you've got a positive output on the alarm. Hook that wire directly up the the parking light wire in your 'Teg.
Wiretaju
Jul 2, 2011 12:34 PM
PurpleAccord88
May 24, 2007 06:40 PM
dek1mfk
Audio / Security / Video
Aug 4, 2005 06:27 PM
hondaracing1
Jul 6, 2004 03:03 PM
IntegraZ
Jul 4, 2003 03:08 PM
