adding a hood popper to viper300
Old Sep 22, 2003 | 08:19 AM
.ShawnD.'s Avatar
Default adding a hood popper to viper300
is there anything need as far as relay's and such for adding an additional popper to the alarm .. i have the door locks i didnt know if i could add one more??
Old Sep 22, 2003 | 08:48 AM
Xsi's Avatar
Xsi
A hood popper? Wouldn't it just pop your hood every time you disarmed the alarm? or if you hooked it up to the boot popper you could do that but you wouldn't be able to have the boot popper as well unless your alarm had two separate trunk/hood release relays
Old Sep 22, 2003 | 06:40 PM
queez's Avatar
Default Re: (Xsi)
well the alarm has a second output you can use for anything, if you had an electronic trunk you can hook it up easily. but if you want it on the hood, you'll have to add an actuator to pop pull the lever, and the actuator can be hooked up to output 2
Old Sep 22, 2003 | 06:45 PM
Xsi's Avatar
Xsi
If the alarm has a second output you can uses a boot popping solenoid and attatch it to the hood release cable, you would have to hide it up in the bumper somewhere
Old Sep 23, 2003 | 12:21 PM
.ShawnD.'s Avatar
yep thats what i wanted to do .. but i didnt know if i needed any relays or such ..
Old Sep 23, 2003 | 07:38 PM
Xsi's Avatar
Xsi
You will need 1 relay
You need to hook the relay so it supplies power to the solenoid when it receives the signal from the alarm
Old Sep 24, 2003 | 04:37 AM
audioroach's Avatar
Default Re: (Xsi)
actually....3 relays are needed ( if you dont want to add a channel expander
onto your system )as well as a selonoid for the 300 system.
The way it works.....press button 2 under these conditions:
alarm armed....hatch can be unlatched.
alarm disarmed...hood can be unlatch.
makes sense? Now this is if you are already using
the channel to work as a hatch release..if not follow the instructions
xsi gave.
Odessa
Audio / Security / Video
Jul 14, 2004 04:10 AM
chris408
Apr 22, 2003 11:24 PM
daxxbomb
Apr 26, 2002 03:17 PM
GoLowDrew
Mar 29, 2002 04:02 PM
mickey513
Oct 29, 2001 02:31 PM
