99 prelude system
Old Apr 6, 2006 | 07:41 AM
dalilman19's Avatar
Default 99 prelude system
hey guys. i plan on getting the following from Elemental Designs:
13Ov.2 Subwoofer
Voice Coils: Dual Two
$165.75
NINe.2X
$225.25
eDi 6500s Components
$212.50
NINe.2
$182.75
Sub-Total: $786.25 shipped
and also the alpine 9856 with the ipod fast link cable from crutchfield.com for $230 shipped
any input on the install and whether I will need sound deadening or a cap or anything like that is appreciated. or how much would i expect a shop to charge to install everything? i plan on getting my wiring from knukonceptz.com will i just need (1) 4 guage kit? or 2? as you can see im working on a budget, so as economical as possible. thanks guys
Old Apr 6, 2006 | 10:25 AM
fcm's Avatar
fcm
Old Fart
Default Re: 99 prelude system (dalilman19)
OK, a few things you have a 600W sub being run by a 1x600W RMS into 4 ohm amp, as long as the sub is a DVC 2 ohm sub it should work just fine. However you have a 2x100W RMS into 4 ohms running 150W speakers, IMO that is under-powering the speakers by 50W a side, although it can work, be careful not to drive the amp into clipping, you can/will damage the speakers.
I would run 4ga, [sub amp] and 8ga, [comp.sp. amp] power kits, [it will keep the power supplies in the amps isolated from each other] if you have dimming light problems and everything else is good, [alt., batt., power and grounds] then I would try a 1 farad cap on the sub amp, [as close to amp as possible and ground cap at the same spot as amp] 94
Old Apr 6, 2006 | 12:57 PM
dalilman19's Avatar
Default Re: 99 prelude system (fcm)
ok cool, thanks for the response. and does anybody else have any input? appreciate it
Old Apr 6, 2006 | 01:06 PM
8520's Avatar
What fcm says is true.
Get a bigger sub amp
kevinm1981
Audio / Security / Video
Aug 16, 2010 06:10 PM
rahfiki
Mar 9, 2009 08:50 AM
aLL MoToR Eg6
Jan 23, 2006 02:22 PM
ukel
Apr 4, 2002 02:53 PM
