98 Ex Climate Control lights?
Old Apr 25, 2005 | 09:11 AM
rey98civic's Avatar
Default 98 Ex Climate Control lights?
After installing an after market head unit in my 98 EX the climate control section of my dash is no longer lighting up. Dose any one know a quick fix to getting them to work agian? I did a search and found nothing.
Thanks!
Old Apr 25, 2005 | 01:31 PM
fcm's Avatar
fcm
Old Fart
Default Re: 98 Ex Climate Control lights? (rey98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rey98civic &raquo;</TD></TR><TR><TD CLASS="quote">After installing an after market head unit in my 98 EX the climate control section of my dash is no longer lighting up. Dose any one know a quick fix to getting them to work agian? I did a search and found nothing.
Thanks!</TD></TR></TABLE>I would pull the aftermarket head unit, [HU] and make sure that wiring going to the climate controls is pluged in properly and isn't pinched off someplace. 94
Old Apr 25, 2005 | 01:51 PM
rey98civic's Avatar
Default Re: 98 Ex Climate Control lights? (fcm)
I'll try that tonight
Old Apr 26, 2005 | 09:16 AM
rey98civic's Avatar
nope that wasn't it. dose anyone a wire diagram for the 6th gen factory radeo?
Old Apr 26, 2005 | 12:13 PM
rey98civic's Avatar
someone please help.
Old Apr 26, 2005 | 12:32 PM
matt_in_sd's Avatar
The lights you are refering to and the dash lights are part of the same circuit. If you are not getting any dash lights in addition to the climate control cluster then you either have a blown fuse or you fried your dimmer circuit. Check fuse 10 passenger side fuse box. Also pull the radio out and verify the red/blk wire(pin 9 on the oem radio connector) isn't shorting to gnd.
Old Apr 26, 2005 | 12:53 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rey98civic &raquo;</TD></TR><TR><TD CLASS="quote">nope that wasn't it. dose anyone a wire diagram for the 6th gen factory radeo? </TD></TR></TABLE>link.....www.installdr.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_in_sd &raquo;</TD></TR><TR><TD CLASS="quote">The lights you are refering to and the dash lights are part of the same circuit. If you are not getting any dash lights in addition to the climate control cluster then you either have a blown fuse or you fried your dimmer circuit. Check fuse 10 passenger side fuse box. Also pull the radio out and verify the red/blk wire(pin 9 on the oem radio connector) isn't shorting to gnd.</TD></TR></TABLE>Ditto that let us know, rey98civic , if it's all the dash lights or just the climate control lights, also chack to see if you have power, [dash lights] when you turn the switch on, right at the one of the bulbs and plug/plugs on climate control 94
cybergreencivic
10
May 2, 2015 09:55 PM
98savage
Jun 16, 2007 08:39 AM
gchino
Oct 30, 2005 07:07 AM
crazyimport
Aug 24, 2004 11:44 AM
N~FaMouSKhMerBoi
Jan 9, 2004 08:53 AM
