97 speedometer lighting, HELP?
Old Aug 10, 2012 | 06:59 AM
Elementcct's Avatar
Default 97 speedometer lighting, HELP?
was wondering if any one could help me figure out how to fix my speedometer light, need to know what wires from the dash i need to replace will post picks when i get home. The CD player was ripped out, so i knew that was what caused it, any pics or wire chart would be helpful thanks.
Old Aug 10, 2012 | 09:25 AM
Elementcct's Avatar
Default Re: 97 speedometer lighting, HELP?
BUMP plz help
Old Aug 10, 2012 | 09:26 AM
Elementcct's Avatar
bump
Old Aug 10, 2012 | 09:36 PM
Bad_dude's Avatar
Have you checked the fuses? How about the lumen dash light adjustment ****?
Old Aug 11, 2012 | 06:59 PM
Elementcct's Avatar
lumen dash light adjustment ****? Where is that located
Old Aug 15, 2012 | 11:19 AM
Elementcct's Avatar
heres some pics guys
Old Aug 15, 2012 | 11:33 AM
Axatax's Avatar
Most likely, your illumination circuit was shorted when that deck was removed.
Nobody can give you a definitive answer based on that picture alone:
1) You will need to get the wiring diagrams for your car (you can get a Haynes manual at any auto part store), and start tracing the red and red/black wires from behind the deck back to your illumination dimmer using a DMM.
2) The dimmer is most likely shot. You can jump this after capping off the exposed red and red/black behind the radio. This will, in 99% of cases, get your cluster lights working after replacing the fuse.
3) When you put your new deck back in, the illumination wire you are concerned with is the black/red. Leave the solid red alone unless you want to end up where you began.
TSIKOY
Honda CR-V & Element
Jun 7, 2013 03:54 AM
LittlesilverEF
Jan 23, 2010 07:52 AM
SupaFly_Honda
Audio / Security / Video
Dec 18, 2006 10:15 AM
00CivicSleeper
Mar 21, 2005 10:53 AM
