8ohm kicker question
Old Nov 23, 2008 | 09:03 PM
lee0149's Avatar
Default 8ohm kicker question
okay i got 2 15" old school kicker comp vr (the ones that have the K in the middle) that is 8ohm and there is only one terminal so i cant lower it. so if i wire both of them up would they be 16 ohms right? what kind of amp can power this the right way. i have a alpine mrv 1002 DC straight 2/1 channel amp and i just bridged it to power these and its bumping hard but i dont want to damage the subs or amp, is this okay?
Old Nov 23, 2008 | 10:56 PM
schmiddr2's Avatar
(2) 8ohm subs wired in parallel(look it up) will be a 4ohm load. I think RMS power is 300watts each. Your amp is 600watts RMS bridged at 4ohm load. So they should be a good match.
The model number of the subs would help to determine the correct power needs and to make sure they're 8ohm SVC subs.
Old Nov 24, 2008 | 04:43 AM
fcm's Avatar
fcm
Old Fart
As mentioned wire the subs in parallel for a 4 ohm load, [wired in series would be 16 ohms] I am pretty sure Kicker CompVR 15", [C15VR] are 500W continuous and the SVC ones, [old school] are 8 ohm.
Although a good amp the Alpine MRV-1002 is underpowered, [for 2 C15VRs] 1x400W RMS into 4 ohms @12V, [1x600W @14.4V].
The amp will drive the subs without any problems, however it will not drive the subs to to their full potential and you do run the risk of damaging the subs VCs if you over-drive the amp into continuous clipping.
If you can keep from "cranking" up the volume you will have no problems, if your a "ground pounder" find a 1x1000W RMS into 4 ohms amp.94
Old Nov 24, 2008 | 07:56 AM
lee0149's Avatar
sorry but i just want to get it straight. the sub have only one terminail and the sub are 8ohm, i wired them pos to post neg to neg then it turns into 4ohm not 16 ohm.
other part i have a jl 1000/1 amp too. this will be okay power for them or to much?
Old Nov 24, 2008 | 07:58 AM
lee0149's Avatar
oh yea if you think its the black and yellow ones its not those. its the ones that are almost or as old as the solo circles.
Old Nov 24, 2008 | 10:17 AM
twentyhurtz's Avatar
yea they should be 400-500w rms each or so, i had (8) svc 8ohm comp 12's in my hatch and they were 150w rms each, yea he is talking about back when they had the round solo's and the kicker impulse and xpl's,
Old Nov 24, 2008 | 10:42 AM
lee0149's Avatar
its the one in the pic. i read some where that these kicker are about 250 rms. giving 2 of them 1000rms would kill them right?
Old Nov 24, 2008 | 12:18 PM
b16a1eg6's Avatar
http://www.the12volt.com/caraudio/wo...s.asp?Q=2&I=81
Old Nov 24, 2008 | 12:24 PM
lee0149's Avatar
okay that helped. wat rms are these subs?
Old Nov 24, 2008 | 12:32 PM
Dang, i don't know, whats messed up is i worked at a kicker dealer back in 01 and we had them and i can't remember. but really i want to say they are less than 500w rms because the 15" xpl's (which are a step above the cvr's and a step below the round solo's) are 350w rms each, i'm pretty sure. So based on that i'm betting they are around 250-300w rms each.
Old Nov 24, 2008 | 05:01 PM
fcm's Avatar
fcm
Old Fart
Are we talking older then 02... http://www.kicker.com/06/tech-suppor...mpVRManual.pdf
Maybe the Comp VR D-series, [C15D]... http://www.kicker.com/06/tech-suppor...ls/CVRdMan.pdf
It's always better to be overpowered then underpowered, you do not have to turn the amps gain up, the JL Audio 1000/1 would work great
Old Nov 25, 2008 | 11:18 AM
yea the pre 02 models, during the round solo era..
freeagent
Audio / Security / Video
Jul 4, 2009 09:49 AM
chinkyx90
Mar 14, 2009 05:35 PM
accordinglyevil
Feb 8, 2008 06:46 AM
thatasiankidtony
10
Sep 12, 2007 03:07 PM
vtec-outlaw
Mar 2, 2002 11:19 PM
