6x9's into EG Hatch (already searched, no luck.)
Old Apr 4, 2008 | 05:21 PM
mizzoEG's Avatar
Default 6x9's into EG Hatch (already searched, no luck.)
Hey guys i have a 94 DX Hatch with no rear speakers or mounts, I know I have pre-wires though. I need any info you guys can give me to achieve this (write-ups, links, pictures, ideas, facts, etc.) I've already searched for months and never got any good info, thanks.
Old Apr 6, 2008 | 03:15 PM
incubus's Avatar
Default Re: 6x9's into EG Hatch (mizzoEG)
6x9 speakers, or any oblong speakers are lousy. In most cases I tell ppl to remove stock 6x9s and go with 6"s they are ideal.
when hatches come with rear speakers they come with 6"s (not 6.5"s) that is what you want to purchase.
A couple of starter questions:
1. Have you upgraded you front speakers yet?
2. what is your goal, or point, to adding rear speakers?
Old Apr 6, 2008 | 08:26 PM
mizzoEG's Avatar
Default Re: 6x9's into EG Hatch (incubus)
When I got my Honda it came with some cheap 6.5's from Dual which are now pretty blown. I plan on replacing them when I also custom install the new rear speakers.
From what I've learned, all 92-95 Civic Hatchbacks came with 6.5"s in the front and Hatches that came with rear speakers (Like Si's) have 5 1/4"s in the back.
For the front are you recommending me to install 6"s instead of 6.5"s?
and also for the rear not to install oblong (oval speakers I assume your refering to) speakers? I have heard also that they are unreliable.
My goal is to have a nice setup with good sound quality and bass on a budget(trying to stay away from subwoofers and amplifiers), I have connected 6x9's to my rear pre-wires for an idea of how it will sound and I was satisfied.
Thanks.
Old Apr 7, 2008 | 06:35 AM
White Smoke's Avatar
i my honda
Global Mod
How do you plan on mounting the rear speakers? I would go with 6.5" in the front and rear...
Old Apr 7, 2008 | 09:07 AM
snarcher!'s Avatar
id like to know about this too..
are there already wires going back there, or do i have to run some from the head unit under the carpets ?
Old Apr 7, 2008 | 09:39 AM
mizzoEG's Avatar
Default Re: 6x9's into EG Hatch (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">How do you plan on mounting the rear speakers? I would go with 6.5" in the front and rear...</TD></TR></TABLE>
That's a very good question because... I don't know! I was hoping someone on h-t could help me answer that. and I would like to wisely go with 6.5's or 6"s in the rear but they wouldn't hit how I want them to. 6x9's are larger and probably harder to fit but i'm willing to try.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snarcher! &raquo;</TD></TR><TR><TD CLASS="quote">id like to know about this too..
are there already wires going back there, or do i have to run some from the head unit under the carpets ?</TD></TR></TABLE>
Well I have a 1994 Civic DX EH2 and I certainly have pre-wires and I'm pretty sure you do too. Just pull your rear seats down, pop out your rear oem non-speaker panels and stick your arm down there for a good dig around. The wire is probably bundled up with a tape or tie and sticking to the inside wall somewhere.
Old Apr 9, 2008 | 04:32 AM
i my honda
Global Mod
6X9"s do not "hit harder" then 6.5"s
Really for the best SQ you don't want any speakers in the rear. But if you were set on doing it, I would get the OEM Honda mounts and put a 6.5" speaker in the rear panels. You can make a custom mount for them but you will still want the OEM grills and it will be rather complicated to fabricate.
Old Apr 10, 2008 | 08:47 AM
snarcher!'s Avatar
what color wire is the positive speaker wire in the hatch rear?
where do i get the mounts to mount some speakers up in there?
Old Apr 10, 2008 | 10:46 AM
i my honda
Global Mod
Default Re: (snarcher!)
VVVV
Old Apr 10, 2008 | 12:16 PM
snarcher!'s Avatar
what the hell does that mean?
from modifiedlife.com
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Front Speaker Size and Location: 6 1/2″ Doors
Left Front Speaker Wire (+): Blue
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size and Location: 6″ x 9″ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Modified by snarcher! at 1:22 PM 4/10/2008
Old Apr 14, 2008 | 07:47 PM
incubus's Avatar
Hondas do not come with 6.5" speakers nor have they ever. It is a 6" stock speaker, the problem is people confuse 6 inch speakers with 6.5s then they had to start calling an actual 6.5" a 6 3/4" because of that mistake.
If you want bass you really should add an amp, one good way to accomplish good bass out of stock locations would be to get some kicker cvt-6.5s or JL w3-6s and run them in the stock rear location off of a 4 ch amp (also running you fronts off it)
Dynamat is your friend.
Old Apr 14, 2008 | 07:51 PM
incubus's Avatar
Default Re: (incubus)
6x9's = anti-sound quality
the problem is that the center area of the cone travels faster than the outer extremities causing the cone to "flex" which creates distortion.
Old Apr 14, 2008 | 09:36 PM
baller status's Avatar
6x9's in a hatch or any case where someone tried to oversize their speakers always results in the same thing: horrible sound and a shortened life expectancy. If you want to oversize your speakers you have to have custom enclosures made. It's critical to isolate the front of the speaker from the rear. It's critical to solidly mount the speaker.
When not mounted properly, the speakers produce little bass. People then crank up the bass on the built in equalizer and that coupled with high volume destroys the speakers.
I'm pretty sure the front speakers are actually 5 1/4. Unless they're a Honda 6 in which case I'm an idiot for not reading these other people's responses more carefully.
Old Apr 15, 2008 | 04:28 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snarcher! &raquo;</TD></TR><TR><TD CLASS="quote">what the hell does that mean?
It mean search dude... This has only been covered 1000 times on this site!
Old Apr 15, 2008 | 08:13 AM
mizzoEG's Avatar
Default Re: (White Smoke)
It mean search dude... This has only been covered 1000 times on this site!</TD></TR></TABLE>
OK since it's been covered 1000 times, how about you do a search for me.
I need to know a way to custom mount a pair of 6x9's, 6.5's, or anything like that, into the back of an eg hatchback with no speaker mounts. Appreciate it.
Old Apr 15, 2008 | 08:44 AM
incubus's Avatar
Default Re: (mizzoEG)
buy the mounts from a honda parts counter then go to your local car audio shop and find some nice 6" speakers.
If you want to do what I reccomended earlier and use 6.5" subs in the rear location, then cut your own mounts out of MDF wood.
Old Apr 15, 2008 | 08:54 AM
mizzoEG's Avatar
thanks but what parts of the mount will i need exactly? and how much will an oem honda dealer charge me for them?
Old Apr 15, 2008 | 10:41 AM
i my honda
Global Mod
Huh.. My search for "rear speakers" came up with TONS of hits....
How about you try again...
This is everything you need, and 200$ is a good price as well.
http://cgi.ebay.com/ebaymotors...ZWD1V
Old Apr 15, 2008 | 03:33 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">Hondas do not come with 6.5" speakers nor have they ever. It is a 6" stock speaker, the problem is people confuse 6 inch speakers with 6.5s then they had to start calling an actual 6.5" a 6 3/4" because of that mistake. </TD></TR></TABLE> Actually Honda/Acura have always come with 6.5" speakers, [or 5.25" speakers] the problem is that they are standard 6.5", all standard 6.5" speakers use a 5" diameter mounting hole and they are round with a 3 hole mounting system, they are being confused with over-sized 6.5" speakers, over-sized 6.5" speakers have different diameter mounting holes depending on brand and even models within a brand, over-sized 6.5" speakers can be round, [multi hole mounting system] or "square" with a 4 hole mounting system, [much like a 5.25" speaker].
This is a standard 6.5" speaker... http://www.eclipse-web.com/point/sp6500.html and other then mounting depth, it is a direct fit into most Honda/Acura, 3 of the mounting holes will line up with the mounting holes in the stock speaker housings.
This is an over-sized 6.5" speaker... http://www.alpine-usa.com/US-e...tab=F it will not fit a Honda/Acura without mods or adapters.
Standard speakers are...
1- 3.5"
2- 4"
3- 5.25"
4- 6.5"
5- 4x6 inch
6- 5x7 inch
7- 5x7 "football"
8- 6x8 inch
9- 6x9 inch
10- 4x10 inch
The above have been used in cars pretty much from the beginning of car audio, it is only in the past 10 years or so that non standard speakers have been used with the over-sized 6.5" developed to cover a number of car make and model specific speakers and the 5x7 football, [Toyota] 5x7, [Chrysler] and 6x8, [Ford] combined into a 5x7/5x7 football/6x8 "universal" speaker. 94
Old Apr 22, 2008 | 10:46 AM
tpan12's Avatar
Have you looked into the JDM speaker mounts by Gathers?
http://cgi.ebay.com/ebaymotors...wItem
fireblaze2k1
Audio / Security / Video
10
Mar 5, 2009 04:41 PM
marc100
12
Apr 26, 2008 06:07 AM
mizzoEG
Aug 22, 2007 01:02 AM
CodyC142
Jan 19, 2007 09:49 PM
