3 subs with a 2 ch amp?
Old Sep 29, 2002 | 07:53 PM
Vp Special K's Avatar
Default 3 subs with a 2 ch amp?
i was wondering if its possible to wire 3 12's up to 1 2ch amp? if it is can you explain how...thank you
Old Sep 29, 2002 | 10:28 PM
TurboBumblBee's Avatar
Default Re: 3 subs with a 2 ch amp? (Vp Special K)
it all depends on the amp and also the subs.. what kind of subs were you gonna get and what amp??
Old Sep 30, 2002 | 06:44 AM
ExAcc's Avatar
I think it is possible, it all depends if your amp can handle the ohm load that the speakers will give. If you buy 3 speakers with 4ohms each, and wire them to be 1 channel, the load will be 4/3 = 1.33333. It your amp can take 1 ohm, then you should be fine. If not, buy 8 ohm speakers to make it 8/3 = 2.666666.
the lower the ohm, the higher the load. Better quality amps can take higher loads.
Old Sep 30, 2002 | 02:14 PM
EBP_SI's Avatar
Default Re: 3 subs with a 2 ch amp? (ExAcc)
depending on the final load you want you could always go with:
2x8ohm in parallel, in parallel with a 4ohm = 2ohm load
2x4ohm in series, in parallel with an 8ohm = 4ohm load
2x4ohm in series, in parallel with a 4ohm = 2.666ohm load
it all depends what you want and what you have already
Old Sep 30, 2002 | 07:08 PM
Default Re: 3 subs with a 2 ch amp? (EBP_SI)
my boy used to have a 3 jl w6 12'' subs in his sebrig and he had a rockford fostgate amp and those subs hit hard as hell.. i forget how he had to wire it, but jl and older rockford amps kick ***..
Old Sep 30, 2002 | 09:56 PM
audioroach's Avatar
The best advice given....3 dual 4 ohm subs wired in series( 8 ohms) or 3 8 ohm subs either wired in parallel...equals 2.66 ( 3 ohms)...a warmm but happy 2 channel amp...if its of decent quality.
have fun
superdat1
Audio / Security / Video
13
Jan 4, 2008 10:42 AM
bradykiller
Mar 31, 2004 06:48 PM
Jonathan_ED3
11
Jul 9, 2003 10:33 AM
cd5_2NR
Apr 24, 2003 02:02 PM
woodog
Dec 17, 2001 11:08 PM
