220amp altinernator???
I am building a system and need a 220a alt. Its going in my ls/vtec swapped del sol. Anyone have any experience buying on? I don't want to buy one that doesn't fit or is a pain in the *** to make fit...
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Yes, price is up there. Tsunami makes a direct fit for your car too as so does many other companies. Glad to see someone doing there system correctly. Stay away from those ebay ones.
I run the Tsunami model on my teg. And I run the dual 280 amp setup on my navigator by Ho.
http://www.highoutputalternator.com/index.htm
This will get you started in the right direction.
WE get our HO alt. from...http://www.ohiogen.com/ they may have something for you. 94
Mechman is the way to go, their website seems messed up right now, but for 200 amps it will probably be around $450 shipped. Ohio Gen is good, just get ready to pay.
I am running a Cascade Omega 15 re-built by team PSI powered by a audiopipe 3kD. Along with a 4 channel amp powering my door speakers(as well as all the other goodies sucking power out of my battery i.e. underglow plasma gauges interior neons boost gauges etc etc) I think a HO alt is needed. And as far as kinetic batterry(s) which one do you audio guru's think would be best???
http://www.kinetikaudio.com/2009/products.asp?C=1
are you looking at replacing your under hood battery or using a power cell?? kenetic cells tend to make crappy under hood starting batteries. had an old coworker go through one every six months. if you use XSPower you can get a D5100R which is a group 51 battery with reverse posts like the stock Honda battery, and is designed for everyday starting use. if you want something to put in the trunk and still have a stock style battery under the hood, then the kenetic cells or XSPower cells will do just fine.
yes on the zero gauge and yes on a quality alt. back in the day streetwires and PG made good ones, i'm not sure now. do know the cheap ones you see littered on ebay are lucky to live 6 months without failing.
Not a honda pic, but my personal suv, 3 kinitc 2400, One under the hood and two in the back of the car. NEver had a problem with the under the hood temp issue.
93first1
May 5, 2006 09:07 AM
