2004 CRV Keyless Entry Install
Old Jul 17, 2004 | 11:00 AM
icmikehunt's Avatar
Default 2004 CRV Keyless Entry Install
I am looking for advice on removing the dashboard pocket on a 2004 CRV in order to install the keyless entry unit. I have done the following from the Honda install instructions for the keyless entry unit:
1. Make sure you have the anti-theft code for the
radio, then write down the radio station presets.
2. Disconnect the negative cable from the battery.
I am now on step 3, which is as follows:
3. Open the lid. Remove the dashboard pocket (one
self-tapping screw, and pull out to release the two
clips and three retaining tabs).
Where I am stuck is on the "pulling out" part (yes, I removed the screw already ). I am concerned about how reluctant the pocket is to come out (i.e. it seems like it's in there pretty tight). The Honda instructions say "pull out", but I imagine there is more to this. If you have any knowledge of doing this without the dash looking like a burglar hit it, I would be very appreciative of any help. For your reference, I have included the keyless entry install instructions from Honda.
http://www.cheaphondaparts.com...2.pdf
Thanks,
Mike
Old Jul 17, 2004 | 01:49 PM
icmikehunt's Avatar
Default Re: 2004 CRV Keyless Entry Install (icmikehunt)
I thought you guys were supposed to be good?
Old Jul 17, 2004 | 08:12 PM
fcm's Avatar
fcm
Old Fart
Hard to explain, hold firmly and give it a quick short jerk,do you fish? if so, its like setting the hook , you want to set it but not rip it out
hope this helps. 94
Jazz GK Hungary
Honda Fit
Feb 10, 2019 04:53 AM
mikeycivic
Audio / Security / Video
14
Nov 28, 2008 11:53 PM
icmikehunt
Acura TL, RL & ZDX
Jul 23, 2004 09:19 AM
mugen22
Jan 19, 2004 08:51 AM
mickey513
Jul 10, 2002 11:22 AM
