2 ohms with monoblock amp?
Old Mar 1, 2005 | 05:05 PM
kap_x's Avatar
Default 2 ohms with monoblock amp?
I'm confused about someting.
I have a Kicker Solo-Baric L7 12" DVC sub, 2 ohms. I'm getting a Kicker kx600.1 monoblock amp that's 2 ohm-stable. How do I wire the amp with the woofer so it will run at 2 ohms, even though it's only one speaker? I couldn't really find it in the FAQ. Any help is much appreciated.
Old Mar 1, 2005 | 05:12 PM
EGPrelude's Avatar
is that kicker 2 ohms run in parallel with 4 ohm coils, or is it 2 ohm coils?
if its 4 ohm coils, you can just parallel the two coils and run it ot the amp. The system will be runinng at 2ohms
Old Mar 1, 2005 | 05:49 PM
matto2413's Avatar
Default Re: 2 ohms with monoblock amp? (kap_x)
if the kickers dual 2 ohms, then you cant wire it to run 2 ohms. you'll only beable to wire them together to run 4 ohms or 1 ohm.if your amps a mono amp most mono amps run stable at 2 ohms. but there are some amps out there that are 1 ohms stable. what you should of done if bought a kicker that daul 4 ohms,that way you can wire them together to run 2 ohms.But as of right now there no way to run 2 ohms with your set up
Old Mar 2, 2005 | 09:04 PM
JTTeG_X's Avatar
also check out the tutorials at http://www.jlaudio.com very useful
Old Mar 2, 2005 | 10:38 PM
sparkz's Avatar
Default Re: 2 ohms with monoblock amp? (matto2413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matto2413 &raquo;</TD></TR><TR><TD CLASS="quote">if the kickers dual 2 ohms, then you cant wire it to run 2 ohms. you'll only beable to wire them together to run 4 ohms or 1 ohm.if your amps a mono amp most mono amps run stable at 2 ohms. but there are some amps out there that are 1 ohms stable. what you should of done if bought a kicker that daul 4 ohms,that way you can wire them together to run 2 ohms.But as of right now there no way to run 2 ohms with your set up</TD></TR></TABLE>
Hes correct. If you have a dual voice 2ohm L7, then your not in a very good boat to be in. You want a 4ohm dual voice coil so that you can wire them up into a 2ohm load (parallel).
8YourV8
Audio / Security / Video
13
Dec 11, 2010 09:50 AM
bennihana
Jul 19, 2004 12:33 PM
93civdx
Dec 2, 2002 09:13 AM
Jan 31, 2002 10:43 AM
jamal-188
Dec 12, 2001 02:41 PM
