12" kicker compVr aluminized subs
Old Dec 12, 2010 | 11:49 AM
Feli's Avatar
Default 12" kicker compVr aluminized subs
i have a pair of 12" kicker compVr's in my 88 civic sedan,just wondering whats the best kind of amp i can use with them with out blowin them
Old Dec 12, 2010 | 06:42 PM
pimpwagon's Avatar
Default Re: 12" kicker compVr aluminized subs
Depends....what's the VC config on your subs? One can't recommend an amp if you dont know what ohm load it will be seeing....well they can, but it wouldn't be good advice..LOL
Old Dec 13, 2010 | 06:14 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^.
A 1x1000W RMS amp is what you need, [1100-1200 watts would be better], the comp VR sub comes as a DVD 2 ohm or DVC 4 ohm, ideally you would have the DVC 4 ohm subs, wire VCs in series, [8 ohms] then wire subs in parallel for a 4 ohm load, use a 1x1000W RMS into 4 ohms amp if they are DVC 2 ohm subs, the best would be to wire VCs in series, [4 ohms] and then wire subs in series for an 8 ohm load and use a 1x1000W RMS into 8 ohm amp, [1x2000W RMS into 4 ohms] you can also wire the subs in parallel, [2 ohms] and use a 1x1000W RMS into 2 ohms amp, [1x500W RMS into 4 ohms]. 94
Old Dec 13, 2010 | 07:01 AM
edzy's Avatar
an amp that does 1000 @ 4 ohms is gonna be stupid expensive lol
Old Dec 13, 2010 | 09:09 AM
mhart's Avatar
who wires **** into 8 ohms? almost all amps today are 1 ohm amps, and a lot are stable down the .25 ohms anymore. to the original thing, you only blow subs when you have a dirty signal (clipping)
Old Dec 13, 2010 | 09:10 AM
edzy's Avatar
I try to wire it to the highest ohm possible
Lower the ohm=more heat & noise
Old Dec 13, 2010 | 09:13 AM
mhart's Avatar
ok, i just wire it to what the amp is made to do.
Old Dec 13, 2010 | 11:39 AM
fcm's Avatar
fcm
Old Fart
As mentioned, the lower the load the more heat, distortion out of amp, the higher the load the lower the heat and distortion and at 8 ohms the bass will be more linear, cleaner/accurate, it is also easier on the cars charging system and a lot easier on the amp.
As for cost of the amp, you get what you pay for. 94
Old Dec 13, 2010 | 06:20 PM
pimpwagon's Avatar
you can also get an amp with a very regulated power supply that does the same wattage at 2,4 or 8 ohms. you better have deep pockets though. and it would be a waste on kicker subs. what is the exact model number so we know what direction to point you in.....
Old Dec 13, 2010 | 07:52 PM
fourtyounceslsh's Avatar
x2
Old Dec 13, 2010 | 07:57 PM
duel_Vtak!'s Avatar
ugh: seriously if you have the money to get like a 2000w x 8ohm amp go for it if not got 1 ohm and use responsibly! i have a lanzar max pro 1800w x1ohm amp that plays for at least an hour before even warming up! have never got it hot yet and yeah she bumps! this is the sub i got it pushin http://www.sonicelectronix.com/item_...-EVW-3000.html
btw i love the sub and company makes pretty dam nice crap triple stack vented rubber souround carbon fiber/kevlar cone nice quality running it on this amp at max 1800 watts doesnt even warm the cone!
CDdubz5
Audio / Security / Video
Mar 23, 2010 06:22 PM
94 SIR
Dec 5, 2008 12:50 PM
I Want An Si
10
Apr 9, 2008 02:53 PM
ReV LiMiT
Mar 12, 2006 02:41 PM
mstewar
Sep 10, 2003 06:54 PM
