1 12inch Solobaric or Two??
Old Oct 27, 2002 | 02:47 PM
Dragger817's Avatar
Default 1 12inch Solobaric or Two??
Here's the Deal, I plan on getting a civic hatchback and i want to custom fit my sub into the spare tire compartment. i plan on using fiberglassto make the box in my tire well. now in your guy's opinion, should i use one or two 12 inch Solobaric? I want Hard tight hitting bass!! I'm pushing both subs with a Rockford bd1000.1 the model before the current ones, and the subs are the original L7, not the new ones. the bass hits good and all, but i'm wondering if i push all that power into one sub will it hit better and tighter?? Or am I better off getting another amp to power each sub? Will there be a major difference?? I don't want my bass to be all distorted, i want it hard and tight. Let me know what you guys think i should do.
Old Oct 27, 2002 | 08:59 PM
Domeskilla's Avatar
Default Re: 1 12inch Solobaric or Two?? (Dragger817)
My friend stuffed a single L7 12 and a BD1000 behind the seat of a regular cab 88 s-10.. if your ears are weak..get the hell out. Since Kicker recommends .88 to 2.0 cubic feet.. i would use one and just bridge the amp.. it wont give it more or less power depending on 1 or 2.. you can make it give 2 the power of one, just have to wire them correctly.. but for EQ, 1 12'.. plus its a weight saver.
Old Oct 28, 2002 | 06:07 AM
2000GSR's Avatar
Default Re: 1 12inch Solobaric or Two?? (Domeskilla)
if your not concerned about weight, then go for 2 of them for sure!!!! If you just put one L7 it won't be that loud and you'll regret it!
Old Oct 28, 2002 | 06:21 AM
97F22B2's Avatar
Default Re: 1 12inch Solobaric or Two?? (2000GSR)
I think you would be very happy with just one Solo.
Old Oct 28, 2002 | 06:47 AM
2000GSR's Avatar
Default Re: 1 12inch Solobaric or Two?? (97F22B2)
you'll be happy with one if your not really into loud stereos... don't believe all that solo-baric **** that one solo is equivalent to 2 regular 12's........that complete BS!!
Old Oct 28, 2002 | 07:26 AM
gokuson's Avatar
2 wouldn't hurt
[Modified by gokuson, 10:27 AM 10/28/2002]
RickR
Audio / Security / Video
33
Mar 23, 2010 06:32 AM
hifonics
Oct 14, 2007 05:08 PM
TegoDC5
Jan 24, 2005 11:10 AM
loki2323
10
Feb 13, 2003 12:24 PM
RevedOut
Apr 19, 2001 10:07 PM
