02 rsx sound system
Old Dec 23, 2007 | 05:06 PM
Elbowpunk's Avatar
Default 02 rsx sound system
how can i hook up my subs/amps to my stock cd player?
thanks
Old Dec 23, 2007 | 06:57 PM
B18C_EJ8's Avatar
No. It's umpossible.
Even with the aid of a Line Out Converter, it's still umpossible.
And although this has been discussed literally hundreds of times, people still think that they're the first ones to ever encounter this dilemma.
Old Dec 23, 2007 | 07:31 PM
BSERIEuS's Avatar
this may help?
http://forums.clubrsx.com/showthread.php?t=500264
Old Dec 24, 2007 | 08:26 AM
Elbowpunk's Avatar
not really cuz he is going threw the bose system and i dont have that option... hmmMmmm
Old Dec 24, 2007 | 08:55 AM
B18C_EJ8's Avatar
Default Re: (Elbowpunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk &raquo;</TD></TR><TR><TD CLASS="quote">not really cuz he is going threw the bose system </TD></TR></TABLE>
How far did he throw it?
Old Dec 24, 2007 | 09:21 AM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">No. It's umpossible.
And although this has been discussed literally hundreds of times, people still think that they're the first ones to ever encounter this dilemma. </TD></TR></TABLE>Nothing is impossible. Pac makes a couple of high power LOCs.
The SNI-15 10-30 watts
The SNI-35 2-40 watts
http://www.pac-audio.com/produ...ifier 94
Old Dec 24, 2007 | 04:32 PM
B18C_EJ8's Avatar
Default Re: (fcm)
I was being facetious. hence the "umpossible" remark. I was saying that in hopes he'd get the hint and search, as he should have done before even asking that question.
Old Dec 24, 2007 | 05:39 PM
Elbowpunk's Avatar
well actually i have a clue, but want to get more answers before i expletive up my car. .... but thanks
Old Dec 24, 2007 | 05:43 PM
B18C_EJ8's Avatar
Well then, so we're not just pissing in the wind here, why don't you tell us what you plan on doing, and we'll tell you if that's the correct way or not.
Old Dec 24, 2007 | 06:42 PM
Elbowpunk's Avatar
pull out the deck
lead in the blue wire from the amp to the antenna wire but i dont get the rca cables, so run a Line Out connector to it...
Old Dec 25, 2007 | 06:48 AM
B18C_EJ8's Avatar
Remote goes to the switched 12v lead going into the deck, not the power antenna. Otherwise, your amp will only be on when the radio is on, and not when you're playing a CD.
Old Dec 25, 2007 | 09:15 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I was being facetious. hence the "umpossible" remark. I was saying that in hopes he'd get the hint and search, as he should have done before even asking that question. </TD></TR></TABLE>OIC, well I guess like sarcasm, facetiousness does not translate well in print, as for "umpossible" I thought it was just a typo 94
Old Dec 25, 2007 | 10:59 AM
Elbowpunk's Avatar
then how do i hook up the rca cables.... or can i go threw the amp has like a plug in with like 4 wires....can i put them somewhere ?
Old Dec 25, 2007 | 11:12 AM
8520's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk &raquo;</TD></TR><TR><TD CLASS="quote">then how do i hook up the rca cables.... or can i go threw the amp has like a plug in with like 4 wires....can i put them somewhere ?</TD></TR></TABLE>
Your composition is awful, I can hardly figure out what you're trying to say.
Like multiple people have already said in this thread, get a Line output converter (Read: Little black box that converts speaker level input in to rca output), some rca's and then go to town.
Honestly though, you don't sound like you have enough common sense to do this well, so I would recommend you take it to a shop that knows what they're doing and have them install it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Nothing is impossible. Pac makes a couple of high power LOCs.
http://www.pac-audio.com/produ...ifier 94</TD></TR></TABLE>
Have you used the trunkloc? We used to use something similar at my old work, but if I remember correctly, we only had mixed success at best.
Old Dec 25, 2007 | 03:21 PM
Elbowpunk's Avatar
well **** i guess i dont kno then... never done a stock deck but wanna try
does anyone kno how and wanna post how to ?
thanks
Old Dec 25, 2007 | 06:25 PM
B18C_EJ8's Avatar
Actually, if you don't have the Bose system, you don't even need to pull the deck.
You can tap any switched 12v source at the fuse box for your remote wire, and you can grab the wires for the LOC at the rear speakers.
Old Dec 26, 2007 | 09:38 AM
Elbowpunk's Avatar
at the fuse.... i havnt been under the dash yet, but does it have wires showing from there, or do i have to tear a bunch of **** off ?
Old Dec 26, 2007 | 10:20 AM
B18C_EJ8's Avatar
As stated above, you seriously need to work on how you word things...
Do you think I'd be able to help people if I typed things like: "You need to tear a bunch of **** off and then connect the wire to the fuse."?? Come on, guy...
Anyways... Use the switched free pin on the fuse box. You don't need to tear anything off.
keepinitrehaal
Mar 20, 2008 11:30 PM
EzThePrez
16
Feb 20, 2008 12:24 AM
ReV LiMiT
Nov 2, 2006 09:53 AM
UCLA.lion
42
Jul 18, 2006 03:08 AM
HONDAzZz
16
Jan 27, 2004 06:22 AM
