saxon's 2010 build thread
official honda whore
Well this summer/fall i started on a 92 si hatch and i was going to put a built B in at first, then i decided to go K
so far from the last car i have alot of parts for the motor build and a couple new parts i just bought
k24a4 block
12.5:1 cp pistons
blue print I beam rods
s2k oil pump (sent out to be modified by erl)
arp headstuds
k-tuned alt relocator kit
k20a2 head
rbc ported manifold with adapter
str fuel rail, with lines and aem fpr (thanks jason)
still undecided on cams/valvetrain
replica 4-2-1 header (thanks jason)
04 type s transmission
04 itr oem lsd (being installed by shaun at IMW)
cc stage 4 clutch
K-pro
koyo rad with fal fan and Spoon rad cap
asr rear bar with jdm itr 23mm sway bar
hoping to put down 280+whp when im done with it and maybe a shot of nitrous if its not fast enough for me
here are some pics of everything i have so far
and pics of the motor/build
still need some things to finish it up but hopefully i will have the motor in the car by spring time and if i have enough money the car will get fresh paint
update:
95 gsr
motor in and running
k24a4 block
12.5:1 cp pistons
arp headstuds
k20a2 head
cc stage 4 clutch
K-pro
update:
95 gsr
well got alot accomplished lately
had the block blue printed and today i gapped the rings (19 top, 21 middle) and picked out my bearings, picked up my a2 trans that i had Innovative Motorworks out of Carlisle Pa freshen up with a new 2nd gear set and oem itr lsd
sending the oil pump out to erl on monday and hopefully have motor together within next two weeks
its slightly used but will polish up great since it only has 500 miles on it
