Project Si
Update!!
3-26-11 pulled ac,cruise and power steering.
Pulling swap out tomorrow. Re locating fuse box and then starting the headlight harness tuck.
Thanks!!
More updates!!!
Engine and trans out, started removing everything that's not going to be used.
Got my t1 catch can and I'm going to be ordering a gtx-3582r
Enjoy!
More updates!!!
Enjoy!
I gave the b16 bottom end to my friend who helped me out with all of my builds. I am selling the head. It has a burnt exhaust valve. If it does not sell I'm going to fix it and put it on my crv once this car is finished...
I need more money to finish the car, that's the only thing holding me back.
I often wish I would have just kept it simple and kept the 3076r that I had and just upgraded later. The car would be on the road if that was the case..
I'm super excited to get this done and get some dyno and track numbers. It's just that I'll probably be getting kicked off the track after a pass or two.. Maybe next winter I'll put a cage in it and make it legit. But as for rite now I have enough on my plate just tryin to get it done. I'm not building a purpose built drag car. Just a street monster that I can run down bikes with
Thanks for all of the positive feedback!
More updates!
Pulled the evap out of the black box under the dash, removed the charcoal canister, pulled the factory fuel filter and Relocated the fuse box to my globe box. Tucked the headlight harnesses,the strut tower plugs,and wiper motor wires. Also flipped the brake booster so the vacuum line is on the bottom.. Still need to tuck the brake lines and clutch line..
this is exactly where im at with my build minus the motor yet lol. im loving that cluster man and that motor is going to be sick. can you pm me about what parts you have laying around i think we are located around the same area
