Project Integra
Old Apr 16, 2009 | 04:11 PM
tegra94proj09's Avatar
Default Project Integra
I recently picked up a under $1,000 integra. I will be working on the body everyday, and will post pics through out the project. Questions comment and Concerns are always great.
Specs 94 Integra ls 2 door.
There is no longer Moldings, fenders, front and rear bumpers on here and rear quarters are now rust free pics will be coming up very soon.!
Old Apr 16, 2009 | 04:49 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Project Integra
welcome to H-T, but these types of threads belong in the Appearance Build forum.
Old Apr 16, 2009 | 07:09 PM
HONDASPANCHO's Avatar
Slaaaam it!
Old Apr 17, 2009 | 06:34 PM
9 hours of work.
Today we patched up the passenger side rear quarter panel.l Bangeg out rear quarter on driver side. Made a patch for rear quarter driver side. Finished welding the holes from the moldings and also filled the area.
Old Apr 29, 2009 | 07:07 PM
G0TB00ST's Avatar
From: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
Im curious to see the outcome
Old Apr 30, 2009 | 05:04 AM
brandonEM1's Avatar
Old Apr 30, 2009 | 11:27 AM
Hey guys we where back to work this week and we have some picture updates.
The passenger side rear quarter is coming along, we had to bring the body line back since it was smashed in and we also patched that area, all the moldings are officially done and we removed the badges from the trunk (welded the holes and then used the appropriate fillers that needed to be used). Here are some pics to track our progress. We are now tackling the pillars and are ready to weld one side, sadly the windshield looks like it has been replaced previously so it was rotted pretty badly...
Old Apr 30, 2009 | 11:29 AM
pics are on the way.
Old Apr 30, 2009 | 02:31 PM
Hey guys today we banged out the windshield, and found bunch of rot. The previous owner replaced the windshield and didn't decide to do it the correct way.
We continued fixing the rear quarter on the passenger side, we had to bring back the body line since it was smashed in and the patch was there.
We also removed the badges on the trunk and welded the holes and used the appropriate fillers. Here are some pictures to track our progress.
MUCH MORE WORK TO GO!
Old Apr 30, 2009 | 02:48 PM
[ej]Jonathan's Avatar
Lord of the idiots
good build!
Old Apr 30, 2009 | 04:47 PM
thanks so much work on this beast but its getting there!
Old May 16, 2009 | 03:19 AM
cheapshot's Avatar
very nice job! my teg needs a similar treatment.
could you post tools and products being used?
i really want to get rid of my quarter panel rust.
the bodyshop wanted to replace both quarters for $$$$.$$
Old May 17, 2009 | 10:32 AM
Sure, in order to fix your rear quarter panel you first will need to determine whether it is some rust or if it's rot. If there is rot you will need to make a patch out of sheet metal. You will need to trace out the shape you need onto cardboard and then onto the sheet metal. Cut out the patch with tin snips. Put the patch onto the panel and form it properly with a body hammer. After that you can weld the patch onto the panel or glue it with a strong glue, whichever you may prefer. Once that is all done you can then go ahead and apply body filler to the area to blend in the area so that it isn't noticeable, you can sand it down after 15 minutes or so. If it is some rust, you can try grinding it out with a grinder, rice paddy or sand blaster. if that's the case you wont need a patch and could just use a filler to get rid of the small rust holes, body filler (bondo), metal to metal filler. Once you put the filler on you gotta sand it smooth. 80 grit sand paper is good. Now a patch isn't a easy job if you are not experienced in this. Once you either made a patch and what not you can prime it then paint it. Of course there is small detailed steps in between you might want to get a helper. Of course this is cheaper to do it yourself and a fun time. But if you don't have the capability's sometimes you just gotta resort to paying somebody.
Old May 19, 2009 | 05:56 PM
Pictures will be up tomorrow of the rotted pillar (now patched and filled, but not nearly done). Also patched a piece in front of rear tire that was rotted out horribly. Progress is coming..just slowlyyyyyyyyyyy! School is coming to a end so it will be difficult to continue this project, but will try.
Old May 19, 2009 | 08:47 PM
MenaceL.A.671's Avatar
wow alot of work! good job bro!!!!
Old May 21, 2009 | 11:26 AM
Here are the new pics..!
Old May 21, 2009 | 12:56 PM
jdmdc2boi12's Avatar
interesting.. keep up the good work! its good u made the pics a bit smaller..
Old May 21, 2009 | 05:05 PM
Thanks the most work seems to be the windshield area, its time consuming since it needs to be pretty perfect so no water leaks and don't want future rusting.
cheapskate
Jun 5, 2016 07:08 AM
austrian type-R
Jul 21, 2006 05:34 AM
hybrid racing
Oct 17, 2004 10:41 AM
