My RHD SSBP Build.
Old Mar 28, 2014 | 12:28 PM
eM1_kiD's Avatar
Default My RHD SSBP Build.
currently in the process of building a RHD 98 SSBP GSR. before this I had a 2000 Civic Si. the Si taught me many lessons, as I was fortunate enough it was my first car and happened to be my first Honda. anyways, picked up this 98 SSBP. currently being rebuilt from the ground up.
car came with no swap, mismatched engine bay color due to the RHD conversion, no rear disc brakes, came on EG front spindles, mismatched interior pieces. nevertheless, still a good build. stay tuned.
Old Mar 28, 2014 | 12:46 PM
eM1_kiD's Avatar
Default Re: My RHD SSBP Build.
UPDATE: the engine bay has been painted, SSBP of course.
also convinced the previous owner to throw in some GSR spindles as part of the agreement we had. got new OEM Timken bearings pressed in, ARP Extended wheel studs pressed in, Moog Lower Ball Joints, both outer tie rods were replaced with Moog ones, and I sprayed my spindles black, for the time being.
also, I have replaced every worn OEM bushing, with an Energy Suspension replacement. starting from the front LCA, to the Rack and Pinion, when I mean, everything, I mean it, haha.
Old Mar 28, 2014 | 12:49 PM
JuggerNaut-CTR's Avatar
Will be following this!
Goodluck!
Old Mar 28, 2014 | 12:53 PM
eM1_kiD's Avatar
Goodluck!
thanks man, will definitely make it an amazing one.
Old Mar 28, 2014 | 03:38 PM
What motor/trans are you thinking of putting in? And what other plans due you have in mind?
Old Mar 28, 2014 | 08:16 PM
slowDB7's Avatar
ssbp is my favorite color, in for this
Old Mar 28, 2014 | 10:03 PM
MattyIce's Avatar
My favorite OEM color
Old Mar 29, 2014 | 08:38 AM
Originally Posted by eM1_kiD
I will be throwing in a B20z for the time being, along with a GSR trans. eventually I will be slapping on a GSR head instead of a B16 head, to raise the cc and probably run ITR cams and ITR pistons for street use, also get some Golden Eagle rods. my main goal is to have around 210 WHP and I'll be more than happy. I eventually want to be on a nano nitrous shot, but that's later on and go B20V turbo aswell, on about 8 PSI, nothing more, but that's wayyyyyyy down the road. I have a Highend tri-y header from my previous build that I will throw on as well and a Whale ***** intake aswell, a SK2 Intake Manifold and 2.5 inch piping, with a tune, of course.
Sounds like a good plan! But, you do know that whole 8psi thing means nothing right? The psi ran through 1 turbo will be different on another. Psi doesnt break things, power does
Post some more pics. Wanna see alla dat ssbp!
Old Mar 29, 2014 | 10:59 AM
eM1_kiD's Avatar
thanks!
Old Mar 29, 2014 | 11:00 AM
eM1_kiD's Avatar
same here man, thanks!
Old Mar 29, 2014 | 11:01 AM
eM1_kiD's Avatar
yeah, I know man , I should have just said low boost, haha. but yeah, the build is going great so far. I definitely will be, I'm actually going to finish installing my Blox Front Endlinks today (yes, I know they suck, lol, JHPUSA was back ordered until next month) and my LCA.
Old Mar 29, 2014 | 03:55 PM
Jake0lson's Avatar
Pretty sweet, the bay looks great. Subscribed, good luck with your build
Old Mar 29, 2014 | 06:56 PM
eM1_kiD's Avatar
thanks a lot man.
Old Mar 31, 2014 | 02:25 PM
eM1_kiD's Avatar
UPDATE: Just a preview shot of the bay, just missing my Lower Control Arms because the Energy Bushings are being pressed in.
also got around to finally install my front sway bar with Blox Endlinks.
need to clean the bay up a little, with the pressure washer. nevertheless, coming out nice.
Old Mar 31, 2014 | 03:57 PM
Kyle8595's Avatar
shooo that color! glwb!
Old Mar 31, 2014 | 04:15 PM
Boosted_90Teg's Avatar
Curious as to why nothing was really removed prior to painting the bay. Could have unbolted the prop valve and moved it out and covered it and the lines in tin foil, heck even the plastic tray in the battery mount is painted, not to mention the fuel filter.
I mean aside from that it looks nice enough, the right hand drive aspect is pretty cool. Looks like it'll be a fun project. But seriously, that paint on those parts doe.
Old Mar 31, 2014 | 09:41 PM
eM1_kiD's Avatar
thanks bro.
Old Mar 31, 2014 | 09:43 PM
eM1_kiD's Avatar
to be honest, I thought about it, but just thought it would blend in with the color of the car. the brake booster, brake lines, fuel filter, I just felt like it would look better SSBP than black or some other color.
Old Apr 17, 2014 | 07:53 PM
eM1_kiD's Avatar
finally got my Buddy Club front camber kit after much research. since they did not come with bushings, I am going to press in my Energy Bushings.
Old Apr 18, 2014 | 06:59 AM
Bluto!'s Avatar
This is going to be good. Badass color to...
Old Apr 18, 2014 | 10:09 AM
eM1_kiD's Avatar
thanks man. I haven't updated it as much with being busy and what not, but there's lots of potential in her.
Old Apr 19, 2014 | 05:56 PM
eM1_kiD's Avatar
build is being put on halt.
Old Apr 20, 2014 | 01:11 PM
slowDB7's Avatar
Why is it on halt
Old May 6, 2014 | 05:26 PM
eM1_kiD's Avatar
Why is it on halt
it was on halt due to some obscurities on the Right Hand Drive conversion being illegal, but I confirmed with some other RHD owners and contacted some CHP officers I train with at their Academy and they said as long as all the VINS match and it is not unsafe to drive on the highway, I should not have an issue.
Old May 7, 2014 | 11:15 AM
runjimirun's Avatar
great looking car man, makes me miss my ssbp teggy. damn . In to see where this build goes
