My 88 std hatch
going to be doing a projector retrofit on my hatch.
decided that i am 100% going to do the projector retrofit on my head lights. here's why:
light pattern (projector on the left, oem head light on the right):
glare (oem on the left, projector on the right):
i have 12k hid's with stock brights and amber city lights. plus tearing them apart will allow me to clean them off since they are all fogged over from the prev. owner installing the city lights.
got some more of my interior installed tonight. car's comming back together nicely.
the projectors i have are from a subaru legacy i believe.
ok so i decided to make a parts list of what all the car has, kind of like what they do in magazines. so here it is
Powertrain:
Powertrain:
- D15B1
- B7 camshaft
- MPFI Swapped with a D16z6 Intake Manifold and Exhaust Manifold
- Stock Internals
- Injen Intake with a Specter cone filter
- NGK plugs and wires
- Ebay Stage 1 clutch, nice and grabby
- std 4spd transmission
- Ebay test pip
- JDM SIR catback (stock sir exhaust)
- Stock GSR shifter
- Stock drums in the rear (for now, disc swap comming soon)
- Stock disc's up front with stock pads (for now)
- Stock 89-91 style LCA's on the rear (going to be refburbing the 88's)
- Stock Struts with Max speed coil overs (not blown and rides good)
- Dx front sway bar
- Unknown status 5 star rims, with some toyo all season 13" tires
- Painted bumpers
- No body damage
- JDM side markers
- Front and rear mud flaps
- Amber corner markers
- OEM Clear bumper lenses with amber bulbs from an EX sedan
- Amber City lights
- 12k HID's
- Fresh 88/89 Moldings
- Ghetto Paint
- Red Civic garnish off of a dx
- Stock std black dash
- Fuzzy coin holder
- Added Cig. lighter
- DX Center Consil
- Ebay Shift Boot
- 98 Prelude seats with a seat pan swap for the fronts
- Newer black carpet
- Black DC Integra rear seats
- DX door panels
- DX Rear speaker pods
- Rear Cargo cover
- CRX Steering Wheel
- Old School Infinity KAPA components up front w spl silk dome tweeters
- Polk 2 way rears w JVC covers
- Two Punch p1's 10"s in a sealed box
- Awsome cool alarm
- Power door locks
- Power Mirrors
- Messed up timing
interior is 95% complete. just need clean up some wires, install my glove box and radio bezel and get a coat hanger clip. also installed a handle on my drivers side window pillar so i can get in and out easier.
front seats:
drivers pillar handle:
front seats:
lol
gimme it back haha jk
dude
i went to do the drivers side OHSH*T handle, the freakin nuts on the back side of the a pillar are not even there...WTF?!?! lol so i wasted a plastic panel...grrrrrrr
dude
fool it doesnt RUN off of BATTERIES it runs off the exssence of NEWBS! lol run it off of Jazzy or someone lol or Ang. Ask her ANYTHING about the engine, she wont answer....i havent even taught her anything about them yet. You gonna join me this saturday to work in the DSM by chance?
thanks man! psh apekd - STFU FOO!! lol my sister doesnt need to know anything about cars. that's your job.
no updates as of recently because i've been busy looking for a job and finishing up high school. graduated last night, class of 2009.
so i've been doing a lot of thinking lately, and was thinking about my motor build up that i'm working on, and thought i would post up what it'll look like
d16a6 block, from what i know no machine work
stock crank
arp rod bolts
stock rods
pm7 pistons
z6 head gasket
z6 head
stock valve train
maybe a skunk2 stage 1 cam
arp head studs
port matched header and intake manifold.
oem rings and bearings
oem oil pump
i know it's a mild build, but should yield some decent horse power for a d series, and according to zeal auto works i should be just under 12:1 compression (like 11.95:1 effective compression.)
question though, for rings, do i just order rings for the a6?
some stuff i'll be doing tomorrow
rear disc swap, 40/40 prop valve, and i'll be installing my blox lca's. going to be messing with my system, to see if i can't find something that i like better than what i have now (without using subs). oh and new front brake pads. and maybe rotors. dunno yet.
stock crank
arp rod bolts
stock rods
pm7 pistons
z6 head gasket
z6 head
stock valve train
arp head studs
oem oil pump
well didn't get the rear disc swap done, i was feelin like ish all day today. but i did get my head lights pulled off and apart and cleaned up a bit, still gotta get all the silicone off and then will finish the projector retrofit tomorrow. i did however buy new brake pads for my disc swap, so i'll be able to reliably stop untill i can afford brembo blanks and hawk blue pads
got the disc swap done last night. all hooked up and blead, i still need to adjust the rear brakes some. also installed rear mudflaps that properly fit the 88-89 style rear bumper, and blox rear LCA's. gotta redo some interior stuff. comming soon: going to be pulling the dash board out and re doing the wiring for my alarm, my speakers my power mirrors and some other things so it looks OEM, IF theives were to brake into my car they wouldn't find stuff, and so wires aren't in the way
also going to replace my climate center and ac thingy with a different one. the ac core has paint all up in it, and the climate center doesn't work correctly. also going to be replacing the heater core diverter thingy cuz it jams up.
man this car seems to be spending more time apart than together. lol. it's ok though, i'm getting lots of work done.
pulled the head off to replace the head gasket that was bad, then decided to continue replacing and fixing bad things and before i knew it i had the whole dash pulled out and i re did some of the wire tuck, and i hooked up the fan how it is supposed to be (through a relay and the fan switch). also got my custom vss setup tucked to where you can't see it. going to tuck my alarm some where hella hidden then put it all back together. while the dash was out i found an OEM radio plug and re soldered it onto the dash harness, and am currently converting my dimmer switch and what not to 90-91 spec. ****'s going to be CLEAN looking when i'm done.
well here's an update, i'm putting the motor in it back together today. i got the wiring almost all cleaned up, just have to re install my alarm then i can put the dash back in. also i decided to relocate my relays for my HID's under the dash instead of in the engine bay, so it looks cleaner. hopefully i'll have it running today
lack of motivation man. probly will be on today, depends on how long it takes me at my grandma's to get **** done.
update:
what started out as a simple head gasket replacement turned into a rewiring ordeal of mass proportions. lol i re did the mpfi conversion again because it was sloppy, replaced the coolant temp sensor and re wired up the fan relay since it was MIA so it will turn on when it's supposed to, not via a switch (h/g blew cuz i forgot to turn it on and went haulin *** up and down the street). i also didn't like where my alarm was mounted, so i did some mods here and there and now you can't even tell that i have an alarm... untill you come to **** w my ****. lol also i have keyless entry hooked up and will have power door locks
which means i can rock my keyless door handles.
i aslo relocated my MAP sensor to some where lower on the fire wall, and using a CR-X fuel filter bracket i relocated my fuel filter down lower and behind the intake manifold. i hate how the engine bay is dirty sparkly gray, even when it's clean it looks dirty. going to attack my engine bay once i get my head on w some simple green and a scrub brush tho.
update:
which means i can rock my keyless door handles.i aslo relocated my MAP sensor to some where lower on the fire wall, and using a CR-X fuel filter bracket i relocated my fuel filter down lower and behind the intake manifold. i hate how the engine bay is dirty sparkly gray, even when it's clean it looks dirty. going to attack my engine bay once i get my head on w some simple green and a scrub brush tho.
yuuuup those nacho's were gooooooooooood.
FINALY got all the wiring done, and the motor all put back together almost.
will be starting it up tomorrow. should be fun!
well yesterday i changed the oil hooked up the map, and it cranked over for a few seconds then started right up. not throwing a single code, idles between 700-800 rpms, and feels pretty nice. thought i had messed up the timing at first, but turns out the dizzy was loose and had advanced it's self all the way forward.
so of course i go to drive it around the neighbor hood, and the brake pedal sinks to the floor. i'm like wtf?? turns out something leaks on the prop. valve. so when it cools down i'm going to check out the brakes. also i need to tear apart my head lights again, the beam is way too low, even when the light's are adjusted backwards.
drove it a little bit up and down the street today, thing still CHUGS gas... but it's aite. i think i've got a bad motor mount or something, whole engine shifts back when i rev it... smokes a bit now, so i think it'll be time for some new rings soon on the b1... then i will mate it w my z6 head. got my rear tweeters installed today, and my alpine speaker amp. yay!! lol
