marcj's farfrumslo EJ8
Old Jun 5, 2009 | 05:57 PM
marcj's Avatar
Default marcj's farfrumslo EJ8
Why hello sirs! I lost my last build thread with an old user name.. So I'm starting over and skipping all the actual previous work and start at where I am now with a very vague introduction, since I plan on doing so much more I figured WHY NOT?!
it started like this:
B16A 9:1 pistons
T3/T04E 57 trim
dog turd drag manifold
dsm 450's
etc.
ran like a champ until the turbo started smoking and blowing oil out of the dp.
picked up this from a member here for $260 shipped
decided to continue running the blown garrett because i'm not very environmentally friendly
picked up great mid-range from the new manifold.. it actually helped spool time too
then I came across this beautiful turbo.. for $170 shipped.
had some problems with fitment.. not only the wastegate was the problem, but the compressor wasn't clearing the cross member
got this idea from a friend
used 3" stainless steel.. all cutting and measurements done by myself
everything fit first time.. had my local exhaust shop weld it up at no cost
turned the EVO intercooler into a backdoor entrance.. spent $30 total
did some tuning
and this is how she sits
Things that I will be updating over the following weeks:
Drag clutch capable of over 400 ft. lbs
3" V-band down pipe (running 2.5" since it's all I had at the time)
3" Thermal exhaust (was waiting until I make the 3" downpipe)
780cc injectors or EVO 560cc and FPR set at 60psi
aluminum radiator since my oem is cracked
reducing IAT since the sinktrap is close to my IC backdoor entrance
DIY water/meth injection system
traction bar
upgrading the ems to ectune ;D
Old Jun 5, 2009 | 06:09 PM
marcj's Avatar
Default Re: marcj's farfrumslo EJ8
oops, I just realized this is the cosmetic section.. sorry guys!
Old Jun 5, 2009 | 08:58 PM
brandonEM1's Avatar
The bay looks good!
Old Jun 5, 2009 | 10:22 PM
Smokinsax's Avatar
The Boot
is that turbo braced at all? does it look like it can supported by that up-pipe alone?
Old Jun 5, 2009 | 11:52 PM
marcj's Avatar
my clutch doesn't hold enough to put massive G's on it, so it's fine for now.. I've checked all of the welds and they look great.
the up pipe is holding the big turbo and the down pipe going all the way past the stock o2 section. I plan on bracing it before I run any more boost.
Old Jun 5, 2009 | 11:53 PM
marcj's Avatar
Originally Posted by brandonEM1
The bay looks good!
thanks
RACEPAK
Oct 18, 2010 07:58 AM
rudysimports
Sep 27, 2010 08:50 PM
mra4886
Feb 29, 2008 12:26 PM
Hulkmanj99
Dec 22, 2005 03:11 PM
