Just an Em2
Old Nov 11, 2013 | 08:46 AM
CleanEm2's Avatar
Default Just an Em2
My build thread is kind of lenghty so here's the link to another forum containing the build itself.
http://www.7thgenhonda.com/forum/showthread.php?t=24652
Exterior Modifications
OEM Aero front lip
"JDM" style grill
VIS OEM style carbon fiber hood
Aero Catch "plus flush" locking hood pins
Type-A sideskirts
WingsWest G5 rear lip
'04/'05 rear tail light swap
Custom shaved door handles and trunk
"Factory Pack Black" painted roof
VMS burnt titanium lug nuts
SpeedStar lugnut taper washers
ARP extended wheel studs
5/16th wheel spacers
'02 RSX-S polished wheels
Suspension Modifications
Polished Neuspeed front strut bar
Energy Suspension front lower compliance bushings
Koni Sport Yellow front and rear struts
Ground Control coilover sleeves
Ground Control/Koni Yellow adapters
'02/04 RSX-S five lug conversion
'01/'03 Civic Energy Suspension rear knuckle bushing swap
Energy Suspension trailing arm bushings
16mm SPC front cam bolts
SPC rear camber arms
Skunk2 clear anodized rear lower control arms
Progress Technology rear subframe brace
Progress Technology 22mm rear anti-roll bar
Corsport V2 Endlinks
Engine Modifications
Semi shaved and tucked engine bay
JDM Dc5R valve cover
K&N crankcase breather filter
'03 Kpro ECU and engine harness
'05 RSX-S Engine and Transmission swap
'05 RSX-S subframe
'05 RSX-S axles
'05 RSX-S shifter cables
'06/'11 Civic Si intake manifold
Hondata Heat Shield intake manifold gasket
BlackWorks Racing throttle body spacer
'02/'05 Civic Si Mishimoto aluminum radiator
Universal Mishimoto 12" electric fans
Gates #21229 upper radiator hose
'02/'05 Civic Si lower radiator hose
ARP head studs
HybridRacing timing chain tensioner
Innovative 75a street/strip swap mounts
ACT 6puck sprung clutch disc
ACT Heavy Duty pressure plate
ACT Streetlite flywheel
'92/'95 Civic throttle cable
Tucked brake booster fitting & line
Rywire dash conversion harness
Karcepts Engineering high volume fuel rail
Aeroquip stainless steel fuel line
Aeromotive a1000-6 fuel pressure regulator
Aeroquip, Fragola, & Summit Racing fuel fittings
Summit Racing 40 micron in-line fuel filter
Walbro 255LPH fuel pump
Karcepts Engineering air condition & power steering delete
Universal coolant catch can
Megan Racing long tube race header
Three inch KTeller exhaust kit
Vibrant 1042 Street Power muffler
HybridRacing RSX gear changing assembly
HybridRacing solid shifter cable bushings
DIY battery lugs
DIY battery relocation
DIY stainless steel clutch line
DIY dipped oil dipstick
J.HA
Jul 8, 2010 01:42 PM
DuceDuceH
Jun 7, 2009 05:11 PM
texasnick
Jul 29, 2004 06:42 AM
Arvid
Jul 12, 2004 11:56 AM
paulzy
Feb 2, 2003 06:49 PM
