BB6 PRELUDE MINI-BUILD
Gettin ready to do some work to my 98 prelude, thought id share some of it with honda-tech. Here are some pics.
info
98 prelude base
h22a4 w/ 93 h22a head
skunk2 stage1 pro cams
boomslang harness, p28, j-k tuning basemap
tanabe super medallion exhaust
blox velociy stack
PLANS>
replace clutch and throw out bearing
replace rear main seal
get dyno tuned
touch up body, clean engine bay
anything i find along the way.
Im going to try to take a lot of pics as i go along and do small things. Let me know what you guys think!
info
98 prelude base
blox velociy stack
PLANS>
get dyno tuned
so my prelude has some nice foglights, but they didnt work. i found the ground to be loose and it has wiring that needs cleened up.
you can see the wires from the front
in the bay
so i jacked the car up, took off the wheel, pulled the fender cover, and ran the wire thru the fender and out near the headlight.
there we go, white wire gone!
fruits of my labor, working fogs and no wires hangin round. more to come.
in the bay
allright did some more stuff. i removed the blox sticker, replaced the yellow coupler with black pleather on it with a black one and replaced the electrical tape on the unused vaccum port with a plug. then i stripped the vc, and sanded, primed and painted it green off of a old accord and cleari it.
before>>>
after>>>>>>>
before>>>
after>>>>>>>
ok so im waiting on some parts so i decided to do some engine bay cleaning.
here is a pic before i started cleaning.
here is a pic of a sensor that is right behind the abs unit that has 2 vaccum lines running to it that are crusty looking. so i took the sensor of its bracket and moved it over by the i.m. it cleans up that side a little bit and i plan on extending the harness and moving it to the firewall or a more hidden location.
you can see where its temp. mounted by the corner of the valve cover.
on this side of the bay i moved this connector and the amp wire.
and the bay cleaned up with meangrean and elbow grease.
i ordered a set of army green lug nuts from zexmotorsprots(a h-t sponser) and they came in and on they went. good deal and fast shipping! also came w/ free magnetic oil plug
rims are dirty cause ive been sanding.
