help engine problem
Old Jan 18, 2012 | 03:21 PM
tackhammer629's Avatar
Default help engine problem
i have a 03 accord it has no compression it has spark and turns over fine and is getting fuel it has a timing chain in tack and tight all valves seem to be moving good but sounds bad does not have the honda crank over sound it was running good just parked it went out the next day and nothin any ideas
Old Jan 18, 2012 | 03:45 PM
Default Re: help engine problem
the car was running great before this no overheating no stalling no it has spark and fuel i checked compression no compression on any cylinders it is a 2.4 4 cyl v tech motor any ideas
Old Jan 18, 2012 | 04:41 PM
vtibrazil's Avatar
sounds bad??? what sound are you talking about??? If you have no compression it doesn't start right? YOu have zero compression on all cylinders?
Old Jan 18, 2012 | 04:44 PM
Dc4LsTeG's Avatar
EK9
^ that. You did a compression test and have 0 on all cylinders? Are you sure your doing the test right?
HondaMike2112
26
Jul 7, 2019 01:16 PM
canabiscris
Nov 18, 2013 10:53 AM
honda_prelude_jay
Jan 3, 2009 03:36 PM
hmtcrxsir
Jul 10, 2007 10:06 AM
InLimbo87
Nov 4, 2004 05:05 PM
