help with chosing throttle body size
Old May 8, 2011 | 01:44 PM
408EJ1's Avatar
Default help with chosing throttle body size
hi im looking to get a throttle body for a build i just finished build the build is:
B18c1 block with jdm itr pistons
balanced internals
Head is a ITR
ferrea 6000 series valves and springs
5 angle port job
mild port job on int and exh side
skunk2 pro1 cams
ITR intake manifold has been cut open to port and polish runners
i was thinking of getting a 68mm blox throttle body but i was told it might be to big
Old May 8, 2011 | 03:29 PM
Uncle Dave's Avatar
Default Re: help with chosing throttle body size
68mm Omni is what I would use on your setup.
Old May 8, 2011 | 03:41 PM
DDTECH's Avatar
I 2nd Dave's suggestion
Old May 8, 2011 | 04:11 PM
1998GsRIntegra's Avatar
I'll third daves. Omni or professional products.
Old May 8, 2011 | 04:24 PM
Uncle Dave's Avatar
I use a 68mm unit on my DD B16a the engine is 100% internally std with good boltons and tuned the car is a pleasure to drive and very good throttle response with a nice powerband for a B16a.All B18 or B20 builds I do are fitted with one of those 68mm units.
Old May 8, 2011 | 05:27 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
I love my omni t.b. it functions almost like stock. every billet t.b. Iv had was complete garbage. they always stick and lock up
Old May 8, 2011 | 05:42 PM
Aesthetic Gains's Avatar
Dos Pupusas
Werd. Thats why I have an OEM throttle body.
Old May 8, 2011 | 05:55 PM
DDTECH's Avatar
I've yet to have a POWER(professional products) TB lock up, i run a 70MM on my own car, and i have 3 builds i'm doing right now with omni 70mm's. I've had skunk2's give me stick problems but never PP or Omni.
Good results will come from a properly matched throttle body to a manifold vs a huge throttle body on a smaller manifold..
Old May 8, 2011 | 06:07 PM
94VTEC2TONE's Avatar
funny i hear alot of guys buying 68mm throttlebodies putting em skunk2 or blox manifolds and not port matching them, seems kinda retarded to me
Old May 8, 2011 | 06:12 PM
Loved
Community Favorite
the skunk2 t.b. is at the very bottom of my list on t.b's that I would run. stock style t.b.s ftw
Old May 8, 2011 | 06:31 PM
408EJ1's Avatar
coo thanx guys for your help. i just ordered a omni 68mm tb
Old May 9, 2011 | 03:29 AM
N/A's Avatar
N/A
Purpose Built
From what I've been hearing the new style s2 tbs no longer have the sticking issue
Old May 9, 2011 | 11:09 AM
Red_Army's Avatar
thats the word.
but as said numerous people compliment PP and omni. i'd go for either one of those. and plan to use an omni 68mm when its appropriate.
Old May 9, 2011 | 12:54 PM
N/A's Avatar
N/A
Purpose Built
Frankly I like them better just cause they're cheap and look oe lol
Old May 10, 2011 | 06:12 AM
90efhatch's Avatar
^^ Thats why I got the Omni TB for my build.
Old May 13, 2011 | 08:13 PM
deary09's Avatar
I have an omni power 68mm throttle body right now and it stick like crazy on my gsr. I'ma try the professional products next.
Old May 13, 2011 | 10:16 PM
BigBlock22's Avatar
hmmmm, this is a first. I haven't heard anything negative about omni throttle bodys... but i think they're both made by the same company
Old May 13, 2011 | 10:22 PM
deary09's Avatar
[QUOTE=BigBlock22;45266693]hmmmm, this is a first. I haven't heard anything negative about omni throttle bodys[/QUOTE
thats true, i only heard good things thats the only reason why i went with omni, but it did me real dirty always stick at 2k+ rpm
Old Feb 19, 2012 | 11:10 AM
Broyo's Avatar
I purchased the 70mm throttle body from Skunk2 and it works great! no problems whatsoever. the car is much more responsive and I can feel it pull harder. I can only imagine how much better it will be once i port match it to my pro-series IM.
Old Dec 17, 2012 | 06:48 PM
smokinrock's Avatar
My 2 cents I believe a type r manifold can't be ported past 65mm so any larger is dumb most aftermarket manifolds can be ported to 69-70mm sometimes ready for a 70 NM in ur case with ur mods depending on rpm spinning 68-70mm is good make sure manifold is port matched if ur spinning high rpms on track day 70+mm I believe real Honda spec. Scca cars run 72+mm
metal41mulisha
Nov 27, 2009 03:59 AM
brand_NOOBian
Mar 31, 2007 04:43 PM
2k1_ITR_0736
Jan 25, 2004 05:06 AM
HYBRIDHATCH92
Apr 2, 2002 05:58 PM
