Cam choice stroked gsr
Old Jan 27, 2016 | 08:12 PM
crazydominicanman's Avatar
Default Cam choice stroked gsr
Stock port gsr head
Super tech valvetrain
Stock intake manifold for now (s2 ultra street with 74 mm planned)
82 mm p30 spec Pistons
Arp head studs/rod bolts
Gsr block
Ls crank/rods
E85
Walbro 320 fp
550 cc injectors
S2 alpha header v1
3" intake/exhaust
Can't decide on cams
Old Jan 27, 2016 | 08:18 PM
4piston's Avatar
Default Re: Cam choice stroked gsr
It's basically a stock engine. Start with the basics
Old Jan 28, 2016 | 05:21 AM
Thanks. just want a larger cam profile than the itr to take advantage of the upped compression. Was thinking to go with either tuner 3's or bc spec 4
Old Feb 3, 2016 | 08:28 PM
Ttt
Old Feb 4, 2016 | 03:16 AM
blackeg's Avatar
so are you looking to make a peak high hp or a broader powerband?
I normally don't recommend itrs on more than 12:1 but thats pump 91-93 octane. with the e85 you will be able to run more timing. it will have a wicked powerband/area under the curve. I could easily see 150 ft lbs and I bet still make 200 whp. itr or maybe bc3+ for power at or below 8000 rpm. just my personal experience I just had an 82x89 mm vtec with itrs.power was good but timing was fuel/ knock limited. with the few more degrees e85 will let u run it will really help a lot
Old Feb 4, 2016 | 11:02 AM
93egSLEEPER's Avatar
With those pistons you will be right at 12:1 static compression. IMO not enough compression or displacement for anything too aggressive. Tuner 3's or spec 4's are better suited for a 12:1+ 2L
Old Feb 4, 2016 | 01:20 PM
TheShodan's Avatar
Moderator
I agree.. Stay with a Pro1/tuner 2, but no more aggressive than a Pro2
Old Feb 4, 2016 | 02:02 PM
I personally think on a stock port head pro 2's may be a hair much even.
Old Feb 8, 2016 | 10:33 PM
Tuner 2 are too small maybe I'll go with the pro 1 since they make good power and torque not just top end
Old Feb 9, 2016 | 05:34 AM
Loved the setup you had here. Hopefully the numbers on this will be similar if not better 🤓
Old Feb 9, 2016 | 07:20 AM
TheShodan's Avatar
Moderator
The difference between the Tuner2 and the Pro1 are simply the primary lobes. Both make very similar peak power, but the Pro1 has a slight advantage in torque curve for that displacement. Smoother VTEC transition with no seat-of-the-pants "VtEc just CRACKED, YO!!" with the Pro1 as with the Tuner2. That was the main reason for choosing that camshaft for "SHE".
That car is still running strong. The owner of "SHE" wants to turbocharge, now.
mathewbyrne
Sep 12, 2012 02:28 AM
B18C1NMotion
11
Jul 13, 2008 01:33 AM
rmcdaniels
11
Dec 18, 2005 01:12 PM
