B18C AllMotor
Hello all im in need of your help im almost finshed my all motor build and want to know what size throttle body and injectors i will need i see throttle body size's anywhere from 62mm up to 76mm dont know what size to go i was thinking 70mm would be ok for myset up and i have been told from a tuner that my stock 240cc injectors would be enuff if i set the fuel reg to 63psi but i dont wanna do that lol just seems alittle nuts so i need help on the throttle body size and injector size's plz and anythink else that would net me more power heres my build.
B18c2
Skunk2 Intake Manifold Port Matched
Skunk2 Fuel Rail
Walbro Fuel Pump
Fuel Reg
Hondata Intake Gasket
Crower Stage 2-3/4 Race Cams
Crower Valve Springs And Ti-Retainers
AEM Cam Gears
Port And Polished P72 Head Decked 10 Thou
Block Bored And Honed And Align Honed And Decked 10 Thou
Arias 12.6 81.50mm Pistons
Eagle H-Beam Conrods
Crankshaft Reground And Balanced
ACL Race Bearings Rods/Mains
ARP Main And Head Stud Kit
Type-r Oil And Water Pump
Spoon LightWeight FlyWheel
Exedy Clutch
JDM Type-r 4.7 LSD Gearbox
Full Honda Gasket Kit
Toda Timming Belt
Xforce 4-1 Race Headers Port Matched
Spoon N1 Exhaust
Hondata S300 ECU
B18c2
Skunk2 Fuel Rail
Walbro Fuel Pump
Fuel Reg
AEM Cam Gears
Exedy Clutch
Toda Timming Belt
Spoon N1 Exhaust
Hondata S300 ECU
For most power goals of your range based from what I can see, at least 410cc injectors (from say an RDX) up to 550cc. Some will jump on here for ID 725-10000 range, but you decide.
have you got a link for the outlaw gasket im looking to make around the 210whp mark i was thinking of going with the skunk2 pro 2 cams but ill see what power i make out of the crowers if im not happy with them i might jump up to the pro 2's
iNDyCRX
Mar 31, 2010 07:16 PM
