B16a2 with ITR Camshafts vs. Standard B16A2 Camshaft. Inconsistent power changes
I have a b16a2 that was tuned to 184hp and now I changed the cams and throttle body for integra type r b18c6 ones
I got It retuned and now it has 163hp can some body explain this or give me a cause I checked the timingbelt again and
Is Ok engine was runnen great before
re: B16a2 with ITR Camshafts vs. Standard B16A2 Camshaft. Inconsistent power changes
compression test / leak down test the engine. that's weird it lost 20 hp with itr swaps.
You made 184whp on a dyno with B16 cams?
163whp with ITR cams and throttle body is normal.
no engine hp
the setup before the cams and throttle body was
one oversize pistons
thin headgasket
chaved head
strenghtend head bolts and valve springs
g4 link ecu
we checked compression and is ok
thin headgasket
chaved head
g4 link ecu
Need more details.
You are saying you had this engine on an engine dyno with the vague setup above and B16 cams. The engine never went into a car or it did and you pulled it back out to try ITR cams on the same exact engine dyno with around the same outside air temps?
This is a professional shop that must have lots of experience having this type of equipment. They have the engine in their dyno cell and can't figure it out, how do you expect us to over the internet? Tell them you posted it up online.
A car dyno that measures engine/flywheel hp would be new to me. You sure it's not at the hubs?
Re: B16a2 with ITR Camshafts vs. Standard B16A2 Camshaft. Inconsistent power changes
JDM_EK_JOE
20
08-04-2008 12:36 AM
9bells
04-10-2007 03:41 PM
